Oct 19, 2009 #2 Mikey P Administrator Joined Oct 6, 2006 Messages 117,120 Not enough weight to OP (grind in the dirt) but it makes a good little pre scrubber for real cleaning ala' HWE
Oct 21, 2009 #4 J Jeff Madsen Guest I owned one years back - it was a POS. The handle release mechanism will break on you, excessive vibration, screws holding the brushcup on to the main shaft shear off, excessive heat build up, etc. etc. My advice is to stay away..
