Over PreSprayed, Under Rinsed
Loren Egland
Antioch, California
Loren Egland
So what was it that he did different?
I was not there during their cleaning but I have observed them clean in the past. So I am just speculating.
I used a a Steam Way Powermatic (bought used from Mikey several years ago) using a kerosene burner along with starting 50 feet 2.5 inch vac hose to 2 inch to the wand and 3/8 inch solution hose. My wand was a 5 jet placed close to the carpet Greenhorn with number 2 sized jets that are old so they may be worn open to a larger size by now. Used a Greenglide hole glide. Basically high flow combined with high heat.
I mixed my prespray strong and concentrated and applied it liberally. I was using liquid Prochem Ultrapak spiked with a little powdered Flex. I used Proline powder carpet extraction detergent by Masterblend with about a 9.5 pH through my machine.
I believe the other cleaner has a newer Cleanco van powered truck mount. He used to have a 4 jet wand with smaller jets than I used and the jets were placed much higher off the carpet than my Greenhorn. So not as much impact, flow, or heat at the carpet wand interface. Not sure if a glide was used. Likely also pretreated with a Hydroforce inline sprayer and surely a different juice mixture. Not able to say how fast the wand moved or how many strokes or what if anything was used through his machine. But the opportunity to completely erase the clean line was clear.
I flush a lot. I never just use water. Only rarely clean on the acid side.
The reason I obtained a picture the same day we cleaned is because I went back to pick up my 4 dryers before a meeting that evening.
Hard to beat a Powermatic with a Cleanco, no matter what chems are used.
GeneMiller
Boca Raton
gene miller
Cleaned a really nasty carpet for the second time. Full of piss and dirt. Heavy pre spray with peroxide and Odorcide. Cleaned it with the hoss at 600psi with no disc the first time. When I was finished I used the zipper to get it extra dry. When finished I left the zipper on the marble while rolling up, proud of the amazing job. When I moved the zipper a nice little puddle of urine was under neath. I spent a fair amount of time on the room but clearly it wasn't as clean as I thought.
This time I took twice as long. I ran the zipper just as before to dry it. This time no puddle of urine but the water wasn't clear. It still showed a little dirt.
Makes me wonder if soft water or ro water would have made a difference.
My last system was junked and never replaced. After the article in cleanfax I know it's time.
Travis Sonderegger
Monticello Utah
Travis Sonderegger
I hate these ones so bad. I had a rug like that a while back. and a piss filled home the lady had used Oxi clean on time after time after time. horrible. Went through so much defoamer with my porty
Total_Rookie
Beaumont, CA
Joseph Torrez
Pre treat is determined by material type, and soil level. Rinse is also accordingly. My method is to apply pre treat to soiled area crb, and re hydrate with water (without soaking soil to the base) to properly hold in suspension until extraction rinse is applied. No need to overload the carpet with chems, but waste money as well.
Interesting topic. I watch vids of guys screaming along with the wand ( various models) and even if they've lightly presprayed they arent rinsing enough. A wand, imo, is like a skill saw; you cant move it faster and expect it to work. Though many guys seem to make it work, at least gives the appearance.
I can make a vacuum plug too (pun intended :-) ); a vacuum can't be pushed faster and expected to efficiently work.
Hawaii
Holy turtle vac, your still kickin!!! How ya been Ronnie?!?
Reactions: Lint Basket
San Francisco, CA
Those bus-turds. Now he'll disappear for another two years.
Hey Ron, you still pre-vac?
Is it worth it?
Hawaii
Is it worth it?
Ronald and I go way back, I've slept through his vacuum presentation at my first Mikeyfest... :shifty:He's one of the few who actually cares about the work he does and I'm happy to call him a friend...
I'm curious how his HX is holding up on his Judson CanAm...
Reactions: Lee Stockwell
