jmo
- Joined
- Apr 11, 2011
- Messages
- 350
- Name
- Jeremy
Why does powermax separate so much? I have to constantly shake my hydro-force for it to stay mixed, did I get a bad batch?
JMO;
PowerMax has one component that does not dissolve immediately.
This is the oxidizer time-release component.
Depending on the temperature of the water, it will take up to 10 minutes, or so to dissolve.
One other factor, may be the amount you are trying to dissolve in the "inline sprayer".
1.5 cups per 5 quart container is the recommended concentration.
Thanks;
Harper and I have been discussing it over on Allsixofus (plus Les) and he is in agreement with me. Everything else equal, price is a factor.
What spray meter tip if any?
If you need a good commercial prespray try EasyXtrat.com I love that stuff. I use a half cup in a 7 qt jug and take out the metering tip. Once in a blue moon I will hit a certain carpet like with any prespray that will take an extra pass but that is not often. AND I have never had a problem with this stuff using it for over ten years.
I was SOLD on powermax for a couple buckets worth. Then I ordered 4 buckets to get the free shipping and holy crap that batch was awful! I almost lost 2 commercial accts before I realized it was the powermax that was causing a heavy duty resoiling issue, at the same time I noticed you couldn't wash the crap off your hands there was so much residue. I like Cobbs and I think they have alot of good things to offer here but they have had blend issues before. On the bright side this is what led me in the search for a new commercial cleaning agent and found Flex/with Citrus and have not had a problem since. It cleaned up those 2 accounts on first cleaning and not a single problem since. Search posts, others like Jim Martin has run into this problem as well.
Porkchop, you really are funny.............................looking!Harper and I have been discussing it over on Allsixofus (plus Les) and he is in agreement with me. Everything else equal, price is a factor.
Yes it's the same one. I don't think that is why they quit making it. But I am sure glad they did.
I am mixing a cup and half and mixing with hot water but still seems to be separating?
My hydroforce has a niftly handle on it that allows me to hold it in one hand and swirl it around to mix the stuff in it.
I must have the only one ...
