knoxclean
How do you clean when the temps are 20 or below. We had some rare cold weather here in Tn last week and I was not able to let our new Sapphire 1200 go out and clean. The first day we could not get water. Turns out the transfer pump froze. The van is parked inside at night but the 40 minute ride to the first job was enough to freeze the pump and hose that supplies the fresh water. The next day I had the guys take a space heater and extension cord and plug in at the customers home and face the heater right next to the pump. Worked fine on the first job but the two quick connects on the front panel froze on the drive to the next job so that van had to be taken off the road for a week. My 3 slide in's were fine because they produce enough heat from the engine.
This week the weather is back in the 40's and 50's but still can't get heat past 175 degrees from the Sapphire 1200? Atleast the lines are not freezing.
Nothing fun about wrenching on a brand new machine
Hopefully we can get it running right before we get busy.
