Replacing solution hoses
Wi
Keith
x2 @Able 1 ... I got some older hose but our local shop doesn't have SS crimps so the steel ones rust out in about 6 months...
No video needed.. Here is an old one:
The piece on the left screws on to your hose (reverse thread) then screw the other piece in all the way..
Noble Carpet Cleaners
I miss the increased heat retention of Parflex and the weight difference. For several years I've resorted to replacing 50' of my steel braided every 6 months. New section goes to font of the line next to my tools and all others get pushed back. I like the way steel braided goes on my reel.
FFA
PA
FFA
I used to use those to patch up hose blowouts on hydraulic lines.
Blue Monarch
Lincoln, NE
Dirk Wingrove
Nice having a parker store in town. Every once in a while, I have them cut off a foot and put a new fitting on. Cheap too!
Reactions: FFA
FFA
PA
FFA
I have one in my neighborhood too that sells hose, but they have to special order this carpet cleaner hose if i want it. Good idea on getting them to put new fittings on.
Blue Monarch
Lincoln, NE
Dirk Wingrove
No other shop in town will put fittings on parker. I clean for the guy who own's the Lincoln and Omaha Parker stores....he says the lawyers are to blame for no one else being able to touch parker stuff.
Reactions: FFA
FFA
PA
FFA
Why is that? What went wrong..
jwfoulk12
PA
Justin Foulk
View attachment 15446 The piece on the left screws on to your hose (reverse thread) then screw the other piece in all the way..
Where do you get these? Ive picked up a few here and there over the years and have been reusing them but i'm do for some new ones.
Boca Raton
I don't find them to be very reusable. They don't cut into the hose the second use. They are a life saver to have onboard. Never used the paraflex, so they may get be reusable for that.
FFA
PA
FFA
This is the hose i use. I get it locally and he can crimp it with whatever i want.
