Apr 30, 2012 #1 D dan mabes Member Joined Jan 6, 2009 Messages 37 What would you use to seal a concrete floor that had a cat urine smell? Dan M
Apr 30, 2012 #2 K P Member Joined Nov 11, 2011 Messages 206 Zinsser Bin if there is something going over it.
Apr 30, 2012 #3 RGH269 Member Joined Mar 1, 2010 Messages 226 Location North Carolina Name Bobby Hales I've used Pro's Choice Odor Barrier worked well.
Apr 30, 2012 #4 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 31,113 Location North East Ohio Name Larry Capitoni what Kevin said Shellac based sealer ..Zinsser BIN is the best ..L.T.A.
Nov 23, 2012 #5 Jim Nazarian Member Joined Oct 7, 2006 Messages 741 Location So. Cal Name Jim Nazarian Is Pro's Choice Odor Barrier a clear product? Does it change the appearance of concrete in anyway? (Unfortunately concrete will not be covered) Last edited: Nov 23, 2012
Nov 23, 2012 #6 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb Dan; We use an acrylic solvent-based Concrete Sealer. It has very good adhesion & barrier properties. http://www3.cobbcarpet.com/zen3/ind...arch_in_description=1&keyword=concrete+sealer It can also be recoated. Larry
