Mardie
Has anyone got a magic recipe for filtration line removal that will work 100% on all different kinds of carpet?
Mardie said:Has anyone got a magic recipe for filtration line removal that will work 100% on all different kinds of carpet?
Yes, but depending on the situation. Usually can be cleaned easier, unless it needed stretching anyway.Ron K said:Anyone ever try re-stretching ?
Ruff Hewn said:Mardie said:Has anyone got a magic recipe for filtration line removal that will work 100% on all different kinds of carpet?
nah, cause not all filtration soil conditions aren't created equal , nor the length time the soil has been accumulating, which condition caused it (generally a negative air draw) , how statically charged on it is, and type carpet all contribute to the myriad of variables that make it easy to impossible to "completely" remove
and if it's from negative air flow thru the walls, it will return if the wall and floor joint isn't caulked and sealed
having said all that, good ole Fels Naptha soap (yea the stuff our grandmothers used) works great .
though it needs thoroughly rinsed and isn't the easiest soap to rinse out either
strong degreasers boosted with oxy work well too
and of coarse there are the juices specifically targeted for filtration soil removal .
From my experience, they're no more full proof or better than the above suggestions
agitation with all above should be assumed too
..l.T.A.
I always explain filtration lines that are evident, to the client when i am giving a quote. I tell them this is not a part of normal carpet cleaning and that it requires specialty stain removal and that the results cannot be 100% guaranteed.Depending on the job and situation i charge $1.00 per linear ft.for the full meal deal. or i just add 5 cents per sq.ft. on the overall job which includes a full detail straight cleaning,which can most times bring the carpet to an acceptable appearance level. I find it is important to mention this before the job so they wont think i did a shitty job.It just sounds like BS if you try to explain it after the job.Zee said:Also depends on how much time one wants to invest in dry vacuuming with the vacuum cleaner's hose attachment...
We prefer to use an actual grout brush (with a long broom handle) along the baseboards after it was pretreated.
Underneath doors just pretreat and any type of agitation method would work as long as there is enough dwell time.
A lot of presprays would break the static bond between the carbon particles and the fiber at hand.
Fels is great too. (97cents at wallyworld so I bought all they had because amazon sold it for 4.99 a piece)
If a customer specificly wants soil filtration removed they will pay extra or I would not do it. That is not regular soil that is included in regular carpet cleaning prices. (your car detailer wont polish up years of neglect on your car, if you just pay for a car wash either)
I appreciate your offer on the ride along,but am in no position or have the time to expand into that area yet.Willy P said:Low moisture air cell technology is the best for that.......... shiteatinggrin
If you can find it in your area, try Ultrachem Clean. It's also a great all around spotter for rust, blood, grease, tar, gum, etc.
You never responded to my offer of getting you a ride along Mardie
I hope that you are not implying that i said or wrote that HWE has anything to do with soaking wet carpet for days because if you are you have clearly mistaken me for someone else.Jimmy L said:Air cell extraction coupled with a revolving multi bristled brush attachment directly on the filtration soil load should do it.
But NOT any form of the soaking wet for days method called HWE.
