She’s finally dry!
We had a medical building that had a 3-inch main break of the 3rd floor of the building running for 4-5 hours. Crazy water, the stairwell looked like water falls as the water ran down them to other floors.
We got the call at 5:00 AM and had 5-crews extracting water for the better part of the day. They left more than 200 pieces of drying equipment and dried most of the CGD carpet in a day. The real problem was the trapped moisture in the walls.
Commercial construction is generally done with metal framing; this framing has a channel in the base plate which will carry water a long way spreading the damage. In this case nearly everything was affected but it was unseen to the eye. When inspecting with a thermal camera you could see that 4-6 up in most areas the drywall and insulation has soaked up some water.
They had few options, that moisture was trapped behind vinyl wall paper. They could remove the wet drywall and insulation, costing plenty but even more importantly the down time, the interruption of business and the mess of sanding and taping would be a nightmare.
The second day we drilled vent holes throughout the 3-floors allowing whatever moisture to escape the passively would. The following days we used 100 turbo vents along with every gadget we had for wall drying, Adapta dry with axial fan’s, Octidry with Axial fan’s, Viking wall drying system, Air Wolf for stair wells.
Everyday we dried and moved equipment eventually drying the whole building. Now the fun of billing it. oh my...
