solution hose
Georgia
I tried that cobbs plastic crap and I went through several of them. Sassy must not like to clean with hot water or he’d be having trouble with that hose also
Eaglewash has been put to the test on my setup and it has outlasted every brand I’ve used.
sassyotto
Wisconsin
Paul
used Goodyear steel braided before. on occasion the heat from the hose would put lines in the carpet I could not even get out with my CRB. Thats why Id prefer not to use it.
Georgia
With your Titan, you should be able to reduce the heat to prevent that. But for steel braided, if you don't keep your water moving, there is always that possibility of those lines.
La La Land
I'm assuming that all steel braided have an inner liner??? Or else you'd get RUST when you 1st pull the trigger.....am I wrong? I threw all my grey hose away for that very reason when they got old...
