Re: Solvent Based Upholstery Protector Survey Scott Warringt
Jeremy N said:
[quote="Larry Cobb":34o3t90w]Just to clear up a few misconceptions:
2. The component that you don't want to breathe,
is the fluorochemical (water or solvent based).
Larry
So should I mask-up when applying the stuff?
Also, when sealing grout with your stuff should I apply more than one coat? If I do then how long between coats?[/quote:34o3t90w]
It is good practice to wear a respirator for
ALL fluorochemicals.
You can also minimize the risk:
by using a long sprayer extension,
and keeping the spray tip close to the carpet or hard surface.
One ample coat of Ultraseal Impregnator,
should be sufficient on most grout lines.
Larry
