Solvent Based Upholstery Protector Survey Scott Warrington
What Solvent Based Protectors Do You Use
  • Total voters
    36
Cleaning Professional
Since Scott Warrington helps me out endlessly when I need technical advice, the least I can do is put this poll up for him!
This one's for you buddy!
Re: Solvent Based Upholstery Protector Survey Scott Warringt
Thanks, Jim.
Now I hate to be picky when getting a favor done, but how about allowing 3 choices so they can select a product and also answer the other two questions.
Done
Try it now
Bump
Come on folks, help Scott (and Cobbs :shock: ) out here, lordy :!: how hard can it be to click a few options.
joeynbgky
Joey
Poll doesnt show up on tapatalk. I have to find mu laptop lol
Sent from my g2 using tapatalk. Whofat
I mostly use water based even on furniture. I will on occasion use a solvent. I prefer Bridgepoint in both cases.
gene
Ron Lippold
I love hardball on most surfaces carpet tile furniture stone showers and the like. No film at all....
Art Kelley
I never use solvent based protectors even on upholstery. I want to live a looong life. Scotchgard (water based), the same stuff I spray on carpets. Works great, never any problems.
John Buxton
I used solvents 18 years ago but the odor was too strong, water based is all I will use.
Just to clear up a few misconceptions:
1. Solvent-based protectors now have a much milder odor.
2. The component that you don't want to breathe,
is the fluorochemical (water or solvent based).
3. Solvent-based fluorochemicals provide the best protection period.
4. New solvents can also meet VOC limits.
Jeremy N
So should I mask-up when applying the stuff?
Also, when sealing grout with your stuff should I apply more than one coat? If I do then how long between coats?
Art Kelley
Jeremy N said:
[quote="Larry Cobb":3ri4a47t]Just to clear up a few misconceptions:
Also, when sealing grout with your stuff should I apply more than one coat? If I do then how long between coats?[/quote:3ri4a47t]
You should definitely mask up when spraying a solvent. Just because something has low or no odor doesn't make it innocuous. The way we work we are inhaling deeply and are in close contact with the chemicals we use. All solvents are toxic and can cause damage to internal organs such as the liver and kidneys. The damage they can cause to the lungs is irreversible. The cancer they cause will really take you out of your game.
Jeremy N said:
[quote="Larry Cobb":34o3t90w]Just to clear up a few misconceptions:
Also, when sealing grout with your stuff should I apply more than one coat? If I do then how long between coats?[/quote:34o3t90w]
It is good practice to wear a respirator for ALL fluorochemicals.
You can also minimize the risk:
by using a long sprayer extension,
and keeping the spray tip close to the carpet or hard surface.
One ample coat of Ultraseal Impregnator,
should be sufficient on most grout lines.
Doug Cox
Doug Cox
Art and John are being close minded on this subject. What "WAS" 20 years ago, is not true today.
joeynbgky
Joey
seems that......... Cobbs and hardball are very popular.. Are they about the same type of product? what differs. I have heard lots of good things about cobbs protector
Jeremy N
My wife swears that the Cobb stuff is really good. She seals lots of grout, so I trust her on this.
Reactions: Larry Cobb
