Stone polishing
BLewis
Lexington
Billy Lewis
I can't wait either! Make sure and post lots of pics and details please!
Albuquerque
Ron lippold
Well I spent half the day stripping the finish off the floor, it had been down for ten years, lots more than I thought. Seems like that's always the case.
I used their traverfill to fill a bunch of small to medium holes and that stuff worked, nice. I have a bunch of pictures, I will post when I'm done polishing, I can't wait.
Before stripping
Total Attachments 5
115
44.3 KB
Size:
105
179 Bytes
Size:
57
106.2 KB
Size:
100
60.6 KB
Size:
76
55.0 KB
Size:
Show Thread & Close Window
KevinL
East Peoria Illinois
Kevin Leach
I almost had to strip some Vermont slate last week. The pastor figured it had 90 coats of wax on it. I was too high. They did it themselves. This guy has rental property that I clean and he does a lot of work himself.
alazo1
San Jose, Ca.
Albert Lazo
I like that traverfill. You can use unsanded grout with an additive that works well but the traverfill dries harder.
Are you using the Diamond Renew?. If yes and you see some swirls after polishing, the 11k monkey will remove them.
Stone and Concrete Polishing
Albuquerque
Ron lippold
polishing
after
not done yet im going to hit a few more areas and seal in the morning, i will take a few more pictures.
Albuquerque
Ron lippold
I had a little issue with swirls but I figured if I reversed my pattern it went away, rinsed about 500 psi.
BLewis
Lexington
Billy Lewis
Sorry everyone didn't mean to reply with quote and repost all the pics
Lance Golden
Surprise, Az
Lance Golden
Ron
Check the surface tension, before and after sealing... and I think you will see for yourself why sealing, may or may not be needed.
Since that job already had a topical, the pores may already be "loaded up" to a certain extent, but the seal you use will "fill" any voids that may not be protected.
And more importantly the grout.
Albuquerque
Ron lippold
O yes I did. My skills are not top notch with the squeegee. I used to remove the haze from the sealer. The 11000 did nothing to the floor except get the haze off. And the grout line are black all over, go figure.
