New high flow/ 6gpm pump, new pressure regulator, no restrictions, accurate gauge and I'm still getting a 300 pis drop when I hit the trigger...
.... Yes?Mikey P said:ACE!
FredC said:http://www.ultimatewasher.com/hose-pressure-loss.htm
Mikey P said:
- no effect.Hook a garden hose directly to the pump inlet. Sure seems like pump is being starved for inlet water somehow.
- put a different unloader on this AM that I had lying around.. had the check valve in it, took it out and still no good.On the left side of the regulator, take off the allen plug. If there is a spring and ball in there, throw them away.
Tried a 07 flow wand today... still drops 250- to 300 poundsWhat size jets are you running again Mike? If you have the ability, put some lower flow jets in your wand and see if it still happens.
