Pretty nice wand.....surprised the hell out of me...I am use to putting the hose on the wand and hearing the air pulling thru it..and when i hooked up to the Stryker it was really quite...it did not sound like air was even pulling thru...
sat it down and it locked itself to the carpet...the back stroke was really nice..the forward stroke will wear you out real quick.....so I opened the relief and it was much better but still tight on the forward stroke....
it flushes out really nice...the recovery is good....the dry time is about the same for your typical wand...it has a nice clean pattern with the dry stroke...
will put it on some residential carpets tomorrow........
the jet bar does worry me....if it gets clogged up..there is just no way that I can see how I can easily clear it out...it could really use a plug on the end that can be removed so you can flush out the bar.....
