I don’t leave dirt behind.CUZ.....when you make yor first pass over yor "prespray " ...its GONE.....
Now what..if theres dirt left yor clear water rinse aint gonna do squat...
Edit: I know I’m going to pay for that comment.
and that was how I realised my clear water rinse wasn't rinsing well, I could do multiple passes on same spot and it would get cleaner.CUZ.....when you make yor first pass over yor "prespray " ...its GONE.....
My thinking is , Why do you need a detergent rinse at all? If your prespray ain't cutting it, then get a stronger prespray. You should not need a rinse for a cleaning boost
It breaks down the pH
Bullshitdo you clean a lot of natural fibre and nylons? use an acid rinse
do you upsell protector? use an acid rinse
do you clean white trash hell holes? use a detergent rinse
do you like doing extra passes to remove prespray? dont use a rinse
Lol all the mill literature I have read has said under 10 ph on stain resistant nylon carpets. I have never seen them say acid rinse.Soil will break down the pH correct
Nylon dyes are acid based dyes and the Mills here stipulate acid rinses are used (nylon is around 80% our domestic market)
Every protector I've read (which is not a lot as we dont get many) says acid rinse
ShawI'd be damned. You guys read mill literature?
Which is the best seller?
Acid also keeps the urine from wicking up from the pad
acid rinse should help kill the funkiness but cant see how the pH changes tendancy to wick?Acid also keeps the urine from wicking up from the pad. I get a lot urine jobs.
please dont rely on personal experiencePersonal experience. I’ve noticed when I clean piss holes with an acid rinse, wicking rarely occurs. I don’t ask why, I just Do
I dated a girl named moreen once.Moreens all..
But do you know what a Devastator filter is?
