...that makes sense, i was wondering about that when i was speech reading...no talk of overcoming a speech impediment
so another vote for a training manual instead of a StandardA cleaning standard should discuss the processes needed for cleaning carpet and at what point you would want a signed waiver to go beyond.
It should encompass the steps involved and why? Always answer the why.
1 pre-inspection - why?
2 Pre-vacuum, Why?
3 Pre-condition (spray) Why
4 Agitation, Why? How? Water pressure, or mechanical? What Type of machine can be used?
(some manufactures forbid the use of rotary machines)
What type of carpet (commercial or residential), (what kind of nap, level loop,
sculptured, cut pile, etc.) what kind of agitation.
5 Extraction (rinse) What psi at the machine,
with what type of carpet (synthetic or man made)
with what type of backing (action back, jute, pet guard, etc)
how many dry passes (could be addressed by regions or zones because of humidity)
Should fans be used (could be addressed by regions or zones because of humidity)
6 Grooming necessary or personal preference.
Your chemistry lesson in the standard should be limited to the Max ph for the type of carpet being cleaned (Nylon, Olefin, Poly, wool, pet)
So who exactly is the standard for? What bearing should it have on carpet cleaners?so another vote for a training manual instead of s Standard
It should be a reference for everyone involved in the industry.......and outside when neededSo who exactly is the standard for? What bearing should it have on carpet cleaners?
Lawyers...So who exactly is the standard for? What bearing should it have on carpet cleaners?
Have you thought about adding them here in our Resource Center for download or purchase
I have one somewhere , buried , from years and years ago LOL. hoping maybe keep monitoring This Thread and Mikey will end up posting the new one, and its entirety and I would not need to purchase a new one LOLCurious how many people in this thread have purchased any IICRC Standard?
A standard is something that should be able to be measured to determine if a job is done properly when looked at through the eyes of an attorney or judge. Thus be able to establish incompetents or negligence otherwise any standard is meaningless. If there is no standard there is no incompetents or negligence. The manufactures have to help set the standard based on actions, chemicals and other things that could damage the goods sold to the homeowner.so another vote for a training manual instead of a Standard
Yet no need for a "chemistry lesson"?A standard is something that should be able to be measured to determine if a job is done properly when looked at through the eyes of an attorney or judge. Thus be able to establish incompetents or negligence otherwise any standard is meaningless. If there is no standard there is no incompetents or negligence. The manufactures have to help set the standard based on actions, chemicals and other things that could damage the goods sold to the homeowner.
is something that should be put in a training manualYet no need for a "chemistry lesson"?
Instead of the technical standard?is something that should be put in a training manual
a standard is something a lawyer will look at to see if it is being met.I don't understand the logic here........................
agreedA training manual should include info from and be in accordance with the technical standard
You are right you don't know me. So whether I am an Idiot or not is not for you to decide.I’ve just decided I don’t know you people or care about your standards
Being here does not make me or anyone else an idiot, Not being here could make me one though. Those not here don't know it.You’re here
Idiot
which is essentially what you have nowagreed
You are right. Basic cleaning instructions should come with any machine sold. OP, CIMEX, CRB, TM, PORTABLESMaybe the problem is a lack of companion materials available.
At the same time, if you don't know how to use the machine, why would you buy it?You are right. Basic cleaning instructions should come with any machine sold. OP, CIMEX, CRB, TM, PORTABLES
