Zee
- Joined
- Nov 2, 2007
- Messages
- 6,177
- Name
It looks like an El Diablo will need a new motor....
It has a Honda GX670 24hp on it. That motor is basically not available anywhere since it was replaced by the GX690.
Any of you have a clue if the GX690 would bolt on and line up with the blower direct coupler the same way as the original engine?
Masterblend doesn't have the Honda engines because they have been building the units with a Kohler. This Kohler is different in size and the exhaust and direct coupler won't line up with the blower. They want over a thousand dollars more for the Kohler than what the Honda GX690 is selling for...plus we would need the whole conversion kit, to set up to match the machine with the new Kohler.
I don't want to spend an extra thousand for that. Especially since we just had the diesel burner's coil replaced last week for $1800!!
