- Joined
- Nov 25, 2006
- Messages
- 8,726
- Name
- Ron Werner
I ran a kero, replacing my HX on Big Red. Keros are meant for high CONTINUOUS flow, not the On-Off flow from normal wanding. A Zipper uses continous flow. (btw FIVE restaurants within 2hrs!!!???) My kero spiked its heat, was too inconsistent, varied from 180 to 240. Burnt out my Neptune hose cause black death and cost me $2000 to replace a carpet.
Plus, the coil started rusting and I couldn't get clean water out of the steel coil, best I could get was an clear orange. Pulled it out and went back to HX and no more problems.
They are also loud and messy.
Can't argue though that they produce the heat. I'd never buy another one however unless they built one specifically for carpet cleaning. They are meant for pressure washing, long periods of continous high flow. not for low flow wanding or upholstery.
I used Propane heat with a 4HT for 5yrs. Best thing is it was more consistent heat because it would heat better with On-Off flow. Plus being copper coils I never had to worry about rust. ALWAYS had clean water. Pressure was good up to 1250psi.
Now I'm running an exhaust HX and with 15 flow at 600psi I don't drop below 200 (conservatively)
If you do need a new HX you can have one made at TTI Custom Fabrication in Florida, formerly John's Hot Heat Exhangers.
