ACE
How do you charge, What do you look for when you preinspect. And how do you clean (PSI, Heat, chemicals).
I have a job in a couple of weeks that has some w2ww. I plan on looking at how it’s manufactured and installed. I might decline to clean if it’s woven.
About 10 years ago I show up to a job on a Saturday morning. The customer did not say, buy the way this is a wool carpet and I did not think to ask test or know by looking at it. I start prespraying with Procyon (non buffered PH 9.5). Before I even plug in the wand the carpet starts to shrink and pull off every tack strip, every seam rips open. I sent an installer friend over to take a look. He tells her the carpet was not properly installed because the seams were not sewn. That got the company I was working with off the hook and I never heard anything more about it. I am now armed with a lot more knowledge about cleaning wool, but to this day I really have no idea how I could have cleaned that carpet with anything but maybe dry foam and not had the same horrible result.
