You can clean 40,000 sq ft with 2 wands in one day? How is that possible ? How long are the days down there?
And to think that Zee has been known to call other cleaners HACKS . Maybe their is more to this thread than what is being told .
We used to do a large corporate office and 4 of us would clean those numbers once a month. It was killer, hands would hurt, my feet had sweat through my socks and I was toast when I finally dragged home. I felt shaky the rest of night, I was so glad when we lost that contract!Why wouldn't you be able to do it? Start at 7am go without stopping until around 12, eat lunch hit the restroom (20-30min) Get the machines up and running and work till 7-730pm. You are done. Only time you stop is to empty waste tanks. An occasional quick snack bite and drink that takes 2minutes is what you need to keep going. (while a helper moves hoses or presprays etc.)
You know... I started typing three times here, to respond to you... Not worth my time. Hack.
Ya prety hard to respond to somthing like that after you stuck your foot in your mouth like that.
40000 sq.ft.x10hr.day NON STOP wanding = 2000 sq. ft. an hr. for each wand. Gooood rincing hey.Do you even use a prespray because if you did i am sure you did not get that rinced out properly going at that speed hey.![]()
"comparisons" on your website....Have you ever seen a room wide open not even a chair or a support column in it that is 35000sqft? You know how much work you can get done in such wide open areas?
Hey aircell brain, how did you come up with those numbers? At best its 1500 1600sqft an hour on each truckmount. And when you say "rincing", I will assume you meant rinsing. Let me tell you a secret: whatever rinsing we achieve by doing 1600sqft...is still a Heck of a lot more than you ever do with the way you "clean" carpet..
I won't change my signature until you change the way you approach this whole cleaning business and stop with your bullshit attacks on good cleaners. Specially on your website...
Btw a 14 inch wide wand with 5 jets can cover a good amount of floor space in one stroke.
Good cleaners can stand on their own. It is hacks like you that i feel quite comfortable exposing.
Mardie I'd tend to listen to you if you'd had years of experience cleaning with a TM but since you don't, any statements you make are just conjecture developed in that wee brain of yours.
You might take it easy on the thinking, you're over taxing brain of yours coming up with your "stories".![]()
) it's all a huge conspiracy against Van shredder hacks. Nobody can clean that much carpet in a day, I don't care how good the equipment unless there is a miracle drug out there for carpet cleaners . How could anyone' back and shoulders take that much punishment ? I have a little time behind the wand and find this hard to believe.
You're right Mardie (you always are) it's all a huge conspiracy against Van shredder hacks.
We are all out to get you!
Run while you can, save yourself!!!!
It is Hacks like Zee that bring this to light not the method. Richard i know you are an old dog when it comes to these bb so could you tell me is it an understood unspoken rule that nobody ever say anything bad about anything to do with steam cleaning carpet. Is gaurding this understood unspoken rule in your moderators hand book ? I love how those that haven't done what we do come here jump around telling us how and what can or can't be done.
Read my comments please. When you have two truckmounts and two wands going for about 12hours straight...why can't you get that done?
I said we would have 5 or 6 people on the job right? Why do you assume the helpers can't take over moving the wand and clean with it? Come on bro! You have 20000 sqft wide open banquet hall for each tm. And 2.5 person to do the work.. you still think one person is unable to wand out less then 10000sqft in one long day?
Please if you haven't had a chance to do this, don't try to think of it in terms of 20 residential homes each being 2000 sqft. Heck no- you could never get that much done in one day. Very different type of work.
Again mardie...you have no experience so stfu. I have done vs for years I know what the difference is. You have zero credibility on here.
Ok seriously the people on these boards represent the best the industry has to offer......I guess in your mind the best of the fookups???
I think forums like this enable the participants to continue to hone our craft not lost on which method is best but offering what ever is needed to get the job done effectively and efficiently.
Remember the major mills recommend HWE, the CRI recommend HWE but I wouldn't use HWE just because they say to. We use it because we have found it to be the most effective on residential carpet, we have also found that low moisture cleaning has left us with the best results on CGD. BUT we have the equipment to do whater is necessary for the particular project. We don't come in with a predetermined idea of what we will be using based on the fact that we offer only one method.
You knock HWE all the time yet as I've mentioned to you that term is too broad to compare unless you are talking about the same machine being used.
Grocery Store Rental
Low pressure Portable
High pressure Portable
Low Pressure Portable with heat
High pressure Portable with heat
Walk behind Portable with low pressure
Any of the above with a powerhead
Walk behind Portable with low pressure & rotating brush
High Flow Extractors the auto feed and auto pumpout
Electric TM's with positive displacement vac blowers, lower Pressure
Electric TM's with high pressure and multiple lamb type blowers
Gas fired TM's Propane designer built (lower production)
Gas fired TM's Heat Exchange designer built (lower production)
Gas fired TM's Diesel Fuel designer built (lower production)
Gas Fired Brand Name TM's Heat Exchange
Gas Fired Brand Name TM's Propane
Gas Fired Brand Name TM's Diesel Fuel
Van Powered CDS or PTO
Truck Powered (Aerotec, Vortex)
Any with Powerheads
Differences in preconditioning with a powerhead, CRB's, 175's, Cimex
I'm sure there are more, these are just off the top of my head, but you like to compare what we at the top end do with the results of those at the bottom end maybe be using. As I've told you before a good cleaner in your town cold cleanup of the competition is truly that weak there.
