- Joined
- Nov 25, 2006
- Messages
- 8,726
- Name
- Ron Werner
Lloyd Dobler said:So Ron you feel that a rotary extractor is a must for a premium cleaner? Anything less is substandard cleaning? :shock:The premium cleaner will do things that do make a difference in the "clean" but may not be as apparent in the visual.
I have a RX20, been sitting for at least 10yrs, no one wants to buy it either. I would never use it without vacuuming first, as much as I can. Cleaned some CGD that it didn't matter how much I vacuumed, there was a lot of soil remaining. Rotary made all the wicking even, no streak marks that were left with the old wands. Don't get that streaking as much, if at all, with the Greenhorn.
From what I've seen with rotaries, most cleaners (excluding some on the board here !gotcha! ) use those to skip steps, ie the vacuuming and the prescrubbing specifically, since the swirl hides a lot of spots. It's all about speed.
Rotaries will not replace a good vacuuming, it may "appear" to remove a lot of junk from the carpet as seen in the filter, but let that carpet dry and you'll pull up a lot of dust and hair that was missed.
A premium cleaner doesn't "need" a rotary, its a nice tool to have available.
Connor said:Yes, but for how long.
And my question was "do you think he did as good of a job"?
depends if he knows how to use his tool. Sometimes, and quite often, service people start relying too heavily on the "power tool" and they do a mediocre job. Look at all the hacks with TM's. They need more power tools to go with their power tools.
