is the chemical jug suction hose pumping out water instead of drawing it up? The chemical injection hoses are pulsating.
Hole in diaphragm or bad check valvesis the chemical jug suction hose pumping out water instead of drawing it up? The chemical injection hoses are pulsating.
I'll check if The flow meter isn't the issue.Hole in diaphragm or bad check valves
I don't run chems through my chem meter/machine. So I would think the diaphragm would last longer.It sounds like you need a new diaphragm.
But what do I know?
