Hey Cobb......
AJR
n Al
Whatshisbutt
Thanks i look forward to using it. I did put a note on my order to cobb that to make sure i get the right batch with citrus lol. i bet he got a kick out of that. i am sure you will be hearing that for as while Larry lol. Good luck
Johnny
La-Z-Boy
Johnny
Does Powermax require more oz/gal since it already has the delim and oxy blended in?
I'll probably get a bucket with my next order of Ultraseal. Is shipping free, as it is with Ultraseal?
floorguy
Utah
Doug
DEPENDS ON what you think more is.....
for me with an electric sprayer, right around 2-4 oz per gallon is the sweet spot...some say they can put 8-16 oz in a hydroforce.....i dunno bout that
when i use the HF, i can still put my 30oz in and mix it well with no issues...
how much seal do you buy??? i think the shipping is based off the $$$ amount bought....so i would guess you might
Jamesh921 said:
2-8 scoops - depending on how dirty it is.
pr gal in an electric or pump sprayer??
I've not tried Cobby's powder, but three heaping scoops of Powerburst pr gal is a max sledgehammer that VERY FEW chems I've tried can compete with (regardless of price or dilution ratio)
..works on BROAD range of soils and carpet types too.
DSC Relief is the only one that's comparable to Powerburst
price isn't as important to me as efficacy in the rathOles
Johnny
La-Z-Boy
Johnny
I use an electric sprayer.
2-3 oz/gal of Extreme Clean, Slop & Gobble, Grease Master, Pro-Zyme (with a little delim and/or oxy, if necessary), gets the job done in most applications.
How does Powermax perform at the same dilution? Or do you need more oz/gal cuz Powermax already has delim and oxy blended in?
dday
BraveHeart said:
Can Cobbs PowerMax be used on StainMaster or Wool ?
I do not and would not use PowerMax on wool ... or cotton ... or most upholstery.
San Francisco, CA
Makes you wonder if the 'enzymes' actually do anything with all these high PH enzyme presprays.
Or is it just the high PH and solvents that mostly do it?
Jay D
DFW, Texas
Jay D
so again for us slow guys :roll: how do we make our current 45lb pails good? and how would you remix a 45lb pail at your home :?: :mrgreen:
floorguy
Utah
Doug
PB sounds like board dejur to me.... :shock: :shock: :shock:
floorguy
Utah
Doug
have any empty 5 gal pails around??? scoop some out to the other one, stir it around add a little at a time, take some more out stir, just keep swapping it back and forth....iffff not....
get a thick plastic sheet dump it out mix around, and scoop back in....when light enough lift and pour in
floorguy
Utah
Doug
I have lightly.....uhhh never thought about cotton.....and works great on most fabrics on uph.....PM and drimaster on microfiber = a-ok
as usual check a small area
Johnny
La-Z-Boy
Johnny
I just found a jar of Dynachem Powermax on the shelves. Clear jar with silk-screened blue labeling. Gotta be 5-6 years old.
What's the shelf-life? Is this the same formula as current PM? It's yellow.
juniorc82
Jefferson City missouri
Jon Coret
Pros choice extreme clean is just as good if not better than power burst. Only 2 oz per gallon it is awesome
Dallas, Texas USA
Johnny;
Shelf life should be six months in original container for maximum performance.
After a year or two, you would still have a basic powder cleaner without the citrus solvent & oxidizer.
Larry
Johnny
La-Z-Boy
Johnny
Johnny;
Larry
Thanks, Larry.
I'll try some fresh PM.
Crawfordville
Danny Strickland
Waldo said:
Is this the same product as 2112 from Carpet Supply Network in Pensacola Florida?
Golden Boy
YES!
probably some small differences, but the same product.
i never had a problem with 2112 and i went through A LOT of pails.
Dallas, Texas USA
Nittygritty said:
Waldo said:
Is this the same product as 2112 from Carpet Supply Network ...?
Golden Boy
YES!
The Dynachem PowerMax formulation is quite different from the "other product".
Talk to the chemists at both companies about the function of all the ingredients.
Larry
Best orange juice on the market by far.
Jamesh921
Central Oklahoma
James
2 - 8 scoops per Hydroforce.
On lighthly soiled carpet, only a need a couple scoops - heavily soiled ratholes get 8 scoops and a citrus boost.
I know PM already contains citrus, but a little extra helps.
Dallas, Texas USA
James;
My house was swaying Saturday night.
The central Oklahoma 5.6 earthquake was the first one I've felt.
How severe was it in your area ?
Larry
Jamesh921
Central Oklahoma
James
We live about 35 miles from the epicenter of the quake. It's the first one I've ever felt here in 47 years and yes, the house did rock some. No damage, but the wife did jump in my lap when the shaking started.
AJR
n Al
Whatshisbutt
Hi Larry
How's my order of PM coming along? I ordered on Nov. 2nd. when can i expect it?
