Joe and Ofer-</SPAN>
We appreciate your loyalty and your feedback. While we may not have asked *
you* the direct question, that doesn’t mean your voice hasn’t been heard (through your distributor, through the Customer Care rep you spoke to, at trade shows, etc.). Rest assured, we do take feedback into our equipment designs (obviously, since we’re changing our float). If you have any other feedback, please feel free to contact me with it, and I will pass it along to the appropriate folks. You may well underestimate how much of your feedback is part of the on-going evaluation of any product we manufacture, as it is a virtually constant communication between our distributors and those at our plant who are part of our Technical Services team and Engineering team. When you communicate your thoughts and ideas to your local distributor, rest assured that information is very likely part of that constant evaluation process. That is one of the reasons why having an international network of distributors is so important, when there are thousands of loyal
HydraMaster truckmount owners just like yourselves who do have valuable feedback to provide.</SPAN>
I work primarily on the chemical and marketing side of the company. So working with Kurt Betton, our Senior Engineer, let us address some of your direct questions.</SPAN>
Great question about the water box. I can't tell you how many water box floats I've replaced throughout the years. Just replaced one this week</SPAN></SPAN>
We recently switched to a new style of floats. Please contact Customer Care if you’d like to retrofit your machine. All new machines ship with it. </SPAN></SPAN>
Why choose an aluminum holding tank that is known to corrode? Your machines are not, by any stretch of the imagination, cheap. Why not use stainless steel, or give the client an option?</SPAN></SPAN>
- We offer an optional sacrificial anode for clients experiencing corrosion issues. </SPAN></SPAN>
- We’ve not had many requests for stainless tanks. Please also keep in mind that while stainless is more reslilient to corrosion, it still corrodes under certain conditions. </SPAN></SPAN>
- It has been our experience in the past that when provided with a stainless steel option at an additional cost, very few folks took advantage of it. There are some exceptions to this.</SPAN></SPAN>
Can last step injection be accomplished? Will it be advantageous?</SPAN></SPAN>
All our machines have been using last step chemical injection since ~ early 2000’s. It avoids passing the corrosive or clogging chemicals through the pressure pump & heat exchanger.</SPAN></SPAN>
Why place the solution metering in the same box right above the electrical connections. Eventually it leaks and corrodes the metal connectors?</SPAN></SPAN>
The current generation of CDS units have the electrical box mounted on the front of the tank, with the solution metering gauge on the side of the tank, mounted in a different panel. The panel with the solution metering gauge has no electronics in it. </SPAN>(</SPAN>
http://hydramaster.com/Products/Truckmounts/CDS48OverdrivewSalsa.aspx</SPAN>)</SPAN></SPAN></SPAN>
Can a shaft that does not need greasing be used? As it is hard to service and shleps around a lot of grease.</SPAN></SPAN>
We are looking at options. Due to the movement of the drivetrain, and potential variations during install, we feel a flexible joint is needed, but we are looking at options to improve serviceability of the u-joint (or eliminate it altogether).</SPAN></SPAN>
Is it absolutely necessary to use proprietary parts? It will definitely mean cheaper repairs for us. Or is it more of a financial decision on </SPAN>hydramaster</SPAN></SPAN>
</SPAN>part?</SPAN></SPAN>
In some cases yes, some cases no. We obviously use many parts that are off-the-shelf (e.g. pumps, blowers, fittings, gauges, valves, switches, etc.) There are other cases where either no off-the-shelf parts exist (e.g. clutch bracket), or parts don’t meet our criteria (e.g. tanks) resulting in proprietary designs. We could simplify the machine quite a bit it we used all proprietary parts (for example, imagine machines with no hoses) but we choose to try and balance between price, availability and meeting the criteria, where possible.
</SPAN></SPAN>
We invite your feedback anytime. Feel free to email me at </SPAN>
doyle.bloss@hydramaster.com</SPAN> and I will pass the information along to just the right team within our company.</SPAN>
Regards,</SPAN>
Doyle Bloss</SPAN>
Chemical and Brand Manager</SPAN>
HydraMaster</SPAN>
