The MFE Boxing Ring!
Able 1
Wi
Keith
I've been talking about a new TM for years. I assumed that 12 flow was a must, but after talking to others who have been at 12 flow and gone back to 6, I'm not so sure anymore. These aren't TEEMF posters either. They are recognized names here. I guess they aren't willing to post about the change because they are afraid a the pack mentality here.
In the last two years I have run 6 and 12 flow ti wands.. I need to go with 12 flow on both(just hasn't happened,yet) 6 flow may be hotter, but the extra flow gives you a better rinse and better dry times (imo).
I think 6 flow sprays too hard and gets to the backing..
To test rub some fels on a spot.. 6 flow will need many more passes then a 12 flow.
Reactions: Cleantechsk
Able 1
Wi
Keith
I know know how you do it..
I'm just suggesting a way to test how well you are rinsing and rinsing the rest of the crap you are using.. It is a eye opener when two passes rinses fes out with 12 flow, 6 flow takes like 6-8 passes..
Hydra Master 575
12 flow 195
6 flow 170
Why 195 on the 575 with 12 flow and way less with 6 flow not possible unless numbers should be flipped error here
Reactions: Russ T.
I think the numbers pretty accurate for a ss570. That's what I've been getting 185-190 atw 12 flow. When my bimba valve was stuck open and I had no temp control it would sit over 200-210 atw.
I think when I tested Toms machine last year I got 220 atw and his machine was sitting at 280 atm must of had a stuck bimba valve because when it's running right it sits at 240 atm all day.
Everest 12 flow 210
6 Flow 225
Butler 12 flow 185
6 flow 200
El Diablo 12 flow 210 fuel fired
6 flow 240
Cleanco 12 flow 175
6 flow 190
Sapphire Scientific
370 12 flow 120
6 flow- not tested
570 12 flow 185
6 flow 210
1200 SE 12 flow 180
6 flow 200
870 12 flow 225
6 flow 230
Aero tech
12 flow 250
6 flow 248
Hydra Master 575
12 flow 195
6 flow 170
Hydra Master direct drive 220 12 flow with their gauge
12 flow 175
6 flow 180
Hydrmaster 423
12 flow 150
6 flow 185
Are we sure the 575 numbers didn't get flipped accidentally ?
170 12 flow, 195 6 flow makes more sense.
@Matt Wood get a lie detector like Nate and see what kinda heat your getting
MLPW
Georgia
I thought about bringing this up, but Mike is a poor sport at making accidents. So I just blew it off it. I'm not gonna buy a tool to use it only once. I know the heat is crazy on this 575. I'll pay shipping if someone wants to send me the tool though
Able 1
Wi
Keith
At the TM.. It will hold around 205 with all of the HX'ers 9 flow at the wand.
