What exactly does that explain , Foam boy?
Figure it out Wet boy
Just like hwe their will be moisture left behind and just like hwe the moisture should be free of contaminants if the operator did his job properly. We all know that nobody can get100% of the impurities out. The moisture left behind with the VS is an encapsulant and will continue to collect any impurities for encapsulation.
I think you should go stick your head back up your ass were it came from.![]()
I used to use a VS 11 upholstery deterger back in the 80's. It did a great job scrubbing furniture although the head was heavy and slow. As a final step, I connected a KleenRite upholstery tool to the vac line on the VS machine and also to the customer's faucet to rinse out the fabric. Otherwise you left a film of VS detergent on the cleaned pieces which normal people understand will attract soil. When I sold the machine to an old VS guy, I told him I did this and he said "What? Are you trying to make us look bad?"A clean water rinse is part of the basic foundation of cleaning since the dawn of time.
As well as the rinsing and flushing action of flowing water, a clean water rinse also has the ability to DILUTE any remaining solutions, so whatever moisture that is not extracted completely and left in the carpet is most likely a extremely "watered down" solution. Whatever moisture or contaminants that are left, if any, are mostly unintended.
Your method INTENTIONALLY leaves a clients carpet coated with what I would think to be a gross contaminant loaded foam/film which consists of full strength cleaning chemicalsfrom your Cimex scrub, more chemicals and polymers from your magic foam, as well as any contaminants, spills and crap that were present in the first place before you moped in.
Commercial situations I can find acceptable.
But residential carpet is a flooring surface that comes into direct, intimate contact with the inhabitants in a very confined space, especially when there are children in the household.
To leave a toxic film such as this on a customers carpet, and proceed to accept money from them and leave, is not something I would find morally acceptable to do.
Dude your von Schrader brain chip is killing me. Have you every used a rotary? If you an rx 20 you would know its getting a lot more than the surface fibers of the carpet. rx or a rotovac once you turn them over after using they are usualy caked with fine sand and sediment. That shyt don't come from the surface fibers amigoLOL You do know that RE only glide across the top of the carpet providing only surface agitation. I can see how they would be great for removing easily available debri and be a thousand times better than a wand. If you want to pull ALL hair dander and other debri that is LOCKED in and BOUND into the carpet fiber and dig the crap out from the base of the carpet is that you need a machine that will dig from the bottom up preferably a machine that has the largest cylindrical brush in the CC industry combined with a foam that will suspend soils and debri and that has a powerful vacuum incorporated into the system for immediate pick up and removal. Just remember just because you sight tube shows clean water only means that your tool has met its limitations and that their is a big difference between sucking it out and digging it out. My comments are in response to the situation of debri removal brought up in this thread.
Dude your von Schrader brain chip is killing me. Have you every used a rotary? If you an rx 20 you would know its getting a lot more than the surface fibers of the carpet. rx or a rotovac once you turn them over after using they are usualy caked with fine sand and sediment. That shyt don't come from the surface fibers amigo![]()
Jon did you not read the statement I made, about why I made the statement you are questioning ? I was having fun with Mikey. You do know he needs to get his feathers ruffled at least once a day and things were getting pretty quiet around here .
Tell me I only clean the tops of the fibers!
The head alone without the machine sits deeper than those shit smearing maxi pads yur pushin pal.
Show your stuff big boy! Put up or Shut up!
Wanna have a Contest?
See who pulls the most crap outta some rugs buddy.
Here's my entry and what you tend to just smear in so!
This thread has turned into craziness
So you think that mess came from rotary extraction just because I posted an image of a head?
I'd be happy to mail ya a bag O the sheet, so you can have it inspected : )
Show us yur maxi pads, it's okay : )
I am just demonstrating that nonsense and
comments can be played both ways seeing is that that seems to be where this thread is heading
It came from that TV show that installs cameras to see how service people behave in their home when they are not their.
lolI don't care about the VS Mardei, Your the one making a big issue out of it with all the ignorant statements, and wild claims that you have been posting on this thread.
I'm just responding to you, and when you get nailed down on a point you run off to something else, and (I'm sorry to see) at times you disgrace your self by resorting to 12 year old mentality debating tactics. You are better then that.
Well for a guy that don't care about VS and surly knows nothing about the operating system you sure do think that you know enough to appoint yourself as a judge of the system. You my good man are FOS. Are we having fun yet.
We wont start having fun till U post up some yo maxi pads : )
Prove What You Remove !
