- Oct 6, 2006
- 116,968
They said it couldn't be done..
Tom Forsythe said hogwash and took the challenge..
• HIGH CLEANING POWER– will surpass all other acidic extraction agents, while rivaling the cleaning effectiveness of the best alkaline formulas, due to its excellent soil suspension and removal capabilities. The result will be reduced cleaning times and very satisfied customers.
• EFFECTIVE NEUTRALING RINSE - Designed for free rinsing and cleaning with all pre-sprays, including high pH products like Flex Powder with Citrus Solv. This neutralization improves bonding and performance of protectors and reduces problems associated with browning and bleeding.
• HIGHLY VERSATILE - Safe to use on all carpet and fiber types.
• HIGH CONCENTRATE, LOW COST - When compared to other acid rinses, it will save money. It is an 100% active powdered formulation resulting in more carpets being cleaned at a lower cost than liquid acid rinses
• EASY MIXING –Dissolves quickly in cold or hot water.
• LOW RESOIL -With the advanced formulation, any remaining residue will not attract soil. Its excellent rinsing capability also reduces the amount of soil remaining in the carpet reducing wicking.
• EQUIPMENT SAFE –**** *** has special additives that help limit corrosion and buildup in the extractor or truckmount, and at the same time, its buffered pH (5.5) is safe for use on 5th generation carpet
Come try this revolutionary new cleaning rinse along with Jim Pemberton and myself at the outside demos next week at MFE
