#20... SS370 build
John Olson
John Olson
And before anyone else asks the blobs you see on the floor are glue. The Dodge had a composite floor glued to it with gaps that would have let water down under and get trapped. When we pulled it those globs where everywhere and an extreme pain in the ass to remove. Being that poly sticks to poly the customer said just spray over it. My spray shop manager hated these pictures and didn't really want to show them but the racks are bad ass :)
Actually yes I do
What's your reason for doing this on an air cooled motor?
Yes that picture was sourced from a shady carpet cleaning forum.
Cleantechsk
Dustin
Are they using the frame kit to avoid the the drill zone? $200 and change from ss I think
S
susclean
noise reduction (not right in front of you)
Dont go home smelling like exhaust
No fumes from exhaust in the van.
ding ding ding - reason number two is why i'm getting the thru the floor added. I just picked up my 370 yesterday she's sweet! the distributor is ordering the exhaust and will install it when i take it back for the 50 hr service
Mikey - two other very minor mods i am having added as well -
1) I had them make up a little section of hose with a male quick connect fitting on each end so that i could make a loop from the pump output to water box input on the front of the machine - this way if i winterize using antifreeze, i fill up the water box, run the pump until i see antifreeze coming out, then hook up the stubby hose so that the pump can cycle antifreeze thru the system for 30 seconds or so - should make sure that it circulates/mixes thru the entire loop
2) on the water pressure gauge, it is a dead end. Really no great way for the water to mix with the antifreeze. At the 50 hr service, they are putting a brass T fitting on the back of the gauge, and giving me a return line with a shut off so that as i cycle antifreeze thru, i can open the shut off and run a little out the end, making sure that the line to the pressure gauge and gauge itself has antifreeze in it.
just sharing in case those sound like good ideas for yer machine (assuming you have cold weather to worry about)
Charlie Lyman
Charlie Lyman
Did you put one on your Rage? How much does the kit cost? Do they have to be welded on?
Scott S.
Scott
no, but i wish i would have. thats why i know so much about them. i believe they are just clamped on.
Also why i was ecstatic about the pro1200se having the threw the floor kit.
Ray???
R
Ron B
The through floor exhaust kit is part # 68-067. It doesn't require any welding. Remove the 2 bolts that hold the stock exhaust in place and replace it with the one in the picture. The kit comes with a 12-14" piece of orange flexhaust hose (cut to fit) and a 3" bracket that attaches to the floor. Pretty simple install with a 3" hole saw.
Scott S.
Scott
mikey, did you go with the small round waste tank or the big tank?
Apo system?
BradFenstermaker
Mike sea if you can bolt plywood to rear door for live waterhose reel.
I love mine with custom 100ft hose on $25 harbour freight reel.
2yrs + old and changed out one swivel
Zee
Those of you that have experience seeing these up close: does the 370 compare to the El Diablo in performance? (other than water temp... Since the El D can be fuel fired)
Scott S.
Scott
the shelf straight back looks awesome.
who, where, how to get one, how much?
Ray Burnfield
Ray Burnfield
Which fancy door should we put the reel on?
Charlie Lyman
Charlie Lyman
How is that hose reel going to make your oil changes? I almost wish I would have nixed the submountt on mine and put my hose reel there. But I like the reel out the back too.
Reactions: susclean
Latest Auctions
