Do you use a whip hose with your wand?
TimM
Ogden, Utah
Tim Magaw
I spoke with him a little while ago and he said the same thing. I'm thinking it is the same hose I am using now. He said my orange hose is most likely flexhaust?
It doesn't bend at all. Ugh! I wish I could just sell it but I couldn't sell something like that crap in good faith...
Just find a new struggling cleaner and either donate it to them or give them a good deal on it.
Ne
I use a 2 inch flexible 15 foot lead hose I got from dultmeiers. Connect it to my stiff hose and use it all the way to my wand. Bright yellow................ $20
Scott S.
PA
Scott
The 2 inch hose you get from John Olsen, is it thick and really stiff? I need to get new vac hose soon. Ive got 300 ft of almost brand new orange hose up in my attic that I won't use because its too hard to work with. I need the lighter more flexible stuff.
I just got a few of those VacAttacks for the 1.5 inch tools, I am hoping they work well!
picture?
i have the light flexible hose on my pro1200se and it got super soft and sucked itself shut saturday at a job. was running on high and it couldnt handle the heat. :(
Kellie Hiler
Kellie Hiler
Scott, I will have to get up into the attic space and pull it down to get a pic which I can certainly do tomorrow....I've got a full day today.
I can say without a doubt, there is no way this hose would ever collapse! But I can also say you definitely don't want it to be your lead hose.
At best I would only consider using it as the outside run from the TM to the door for me anyway.
The one time I used it, I was very thankful the house was vacant as I am quite sure I would've been buying some knick knacks and tables!
Kellie Hiler
Kellie Hiler
Jimmy, at one time, we tried doing that with this hose but even my husband got frustrated with it....and he was very strong at the time!
Scott S.
PA
Scott
ehh, dont worry about taking a pic. i was just curious.
IL
I doubt it's this stuff http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=72&products_id=3620
Compared to the stuff we got with the tm, I can't imagine a better hose.
If your orange hose has a light blue inner lining than it might be this. I doubt it, stuffs pretty bendy.
I have no idea if this is the same hose John has. It's hard to tell when it has different names.
N GA
BradFenstermaker
Yes Mikey. I will grab a tape in the am and measure fur ya. It's ben getting shorter this year cause its getting old and cracking like Suckley.
I think it is the no name. You posted some pictures of the 1.5" tubed model. I like the looks of the two piece glide.
the No Name (From Devastator Tom ) has not been seen but by a very few. No pics here.
No mention of it's glide so I think you are thinking of the Mach 12.
but YOU will wand a No Name for sure.
and I'm also pretty sure that we'll be having a Name The no name Wand contest here before Atlanta.
Dallas, Texas USA
The 15' tapered hoses give you quite a bit of airflow improvement over the 2 inch reduced to a 1.5 inch whip but all the ones I have seen or used are a single ply hose that just will not hold up to the everyday vacuum and heat of a truckmount.
These hoses are typically used on car wash vacuums.
Let me know if this one is a 2 ply hose but I doubt it.
Durability is less than the Superflex 2" hose,
so just keep that in mind .
f11Z3Q9-Q429-GeqYbC0TAPqYqYxT30t1naAZfNfLQ8sdvQ3Hh1M8XlRlnpnw-RAKw2FKGa3UaApT17R5sI=w560-h995-no.jpg
Reactions: dgardner
Loren Egland
Antioch, California
Loren Egland
I use my steam way wand a lot on heavy soil, Love the flushing with K3 flood jet and the 1.5 pipe works fine. Pretty easy to sling around
As mentioned the number on the flood jets needs to be doubled to be equivalent to a normal wand jet for flow rate.
3 = 6, 1.5 = 3, etc.
I don't use the Steam Way wand now that I rotary jet extract, but otherwise it would be used most of the time to compensate. 6 flow at 2 inches from the surface makes for high impact clean & flush and at higher temperatures, especially with the protection shield. The smooth design shape of the vacuum allows for good cfm through a 1.5 inch wand.
Using that Steam Way wand with a kerosene burner is what made me slow to adopt rotary jet extraction. Even then I got tired of sometimes needing to chop stroke. Eventually took the easier route.
