- Oct 6, 2006
- 117,324
2000 rpm's over the 1500 for a traditional cds 1400 for a pro1200.
Bob, not sure but from what was showed I believe the generator runs off the same serpentine belt that drives the rest of the engine accessories.the belt on the generator could be difficult
Chris, not a direct comparison. The new machine drives the blower at different speeds depending on the speed switch on the front of the machine, while the engine always turns at 2000 rpm. the fuel consumption will be very different depending on the blower speed setting.I'm interested in the fuel usage of the v6 at 2000rpms vs the 6.0 at 1500
Definitely! They mentioned in the video that the generator produces 18kw (18000 watts). The basic conversion is 746 watts per hp, so 18000/746 is roughly 24hp, a pretty hefty electric motor.That electric motor must be a beast to be able to spin that blower and hold a load on it.
Sam,
Keep in mind that you have to think a little differently than with traditional cds-type machines. The quoted speed is only for the van's engine and is constant. The blower can turn at any speed - set by the electric motor controller (four different preset speeds). As you increase the blower speed the van stays at 2000 but the generator loads the engine down more, increasing fuel consumption, and vice-versa as you lower the blower speed.
Sam, imagine sitting in your car with the shifter in park. hold your foot on the gas and rev it up to 1500. Now rev it up to 2000. The fuel consumption will be nearly identical because there isn't any load on the engine, it's spinning freely. The fuel consumption changes when you load the engine down. With the x-Drive the engine is loaded electronically, not by changing engine speed.I'm also interested in how much fuel savings between 1500 and 2000 rpm's
Well, sure, to a tiny extent. No engine spins completely freely, there is internal friction and accessories to drive (like the water pump, oil pump, alternator), but that's focusing on pennies while ignoring the dollars.I would think accelerating the gas would use gas.
Get outta town..... Really?18 Kilowatts is around 25 hp
As soon as Doc slips on a tub, hitting his head and builds the flux capacitor.When are they gonna upgrade it to 1.21giggawatts![]()
