Acid rinse directly into fresh water tank?
Jeremy Martin
MN
Jeremy
My chemical pump is broken for good. Anyone put acid rinse directly into fresh water tank? If so, help with dilution ratio? Maybe just a pump up sprayer mist after rinsing with fresh water is best until I get the pump replaced?
Fort Worth , Texas
I do tire SOMETIMES of being right most of the time.
Ann Arbor
Steve Lawrence
Hmmm, I wonder what the long term affects of running a rinse through all that important hardware might be? I'm not willing to find out. I don't use a rinse product but our water is slightly acidic so maybe it's not as helpful here.
Jeremy Martin
MN
Jeremy
Yes, I'm wonder this and if deemed ok to use how to find the dilution ratio. My acid rinse is 1-2 cups into 5 gallons but then metered at 2 gph
If I had to chose which rinse to put in the water tank, I’d chose soda ash over acid rinse.
San Francisco, CA.
soda ash will more damage then acid rinse.
the secondary goal of the rinsing phase is the bring the fiber back to a neutral ph, which is 7.
pre spray is 8.5 :biggrin: up to 14ph:eekk:. A 2-4 ph acid rinse helps reach a 7.
@dealtimeman is right-----1 gallon acid to about 100 gallon water is about right since its NOT getting diluted as it would in a mixing tank.
I'm less concerned about the ph of the carpet as I am of the condition of the components of the water system in the tm (water pump, pressure regulator, etc). Would the soda ash do more damage than an acid rinse in the water pump?
Reactions: hogjowl
if the manufacturer say X and your using a water softener cut it in half!
Also how big is your fresh water tank?
San Francisco, CA.
Alkaline cleaners leave deposits inside the plumbing of the heat exchangers, reducing their efficiency and even clogging them in severe cases.
Running an acid through the system will clean out those deposits.
hydracat
olympia wa
I haven't had a chem injector in years. Never had a problem. It can leave fuzzy looking stuff in the bottom of the tank. Probably fillers or stabilizers of some sort. Using flex ice for a while now.
Acid cleaners do the same thing. Has nothing to do with acid or alkaline. Has to do with the make up of the product. Vinegar or descaling products clean out your system because they have no soap or detergent products or fillers. Acid cleaners leave as much residue as alkaline cleaners.
icleancarpetz
Rafael Samson
I’d say about 16 oz for 75 gal
I made the mistake of dumping into 75 gal tank half gal to a gal using all fiber rinse from JonDon. Stuff ok but foams up. Lesson learned. So now if a had to it, 16 ounces is the sweet spot for me.
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
Most rinse products should be diluted at either 1:320 or 1 :640. Use 1:640 if you have soft water. 1:320 if you have hard water. Somewhere in between is OK for most.
100 gallon fresh water tank would need somewhere between 20 and 40 ounces. A quart would be a nice round amount.
I would run an emulsifier for my rinse if I had to dump it right in the tank. Just dilute it a lot. Wayyy cheaper and easier on the parts.
