Who makes poly, ss or custom waste tanks for tm?
icleancarpetz
Rafael Samson
Looking to replace the steel waste tank for a lighter tank. Who makes poly waste tanks or similar for truck mounts
Mytee makes poly waste and fresh tanks. Not sure what the max size blower you can use with poly tanks, Nor if they work in the real world.
to echo John, Mytee is the only one I know of that makes a poly waste tank .
No clue whether it's worth a squat.
Does Cobblet use them in his Cobb-o-matics??
Most any fab/weld shop can/will make a tank of stainless or aluminum to your specs.
Important/critical note....copy a known good tank design, cause they're much more than just an empty can....
Internal baffles/supports are needed keep recovered water out of blower and to prevent premature weld fail due to tank vac flex
aluminum is obviously the lightest, but not without it's pitfalls of internal corrosion and pitting.
within as little as 5-6 years the tank bottom may need some bubble gum stop leak repairs due to pitting .
Easiest repair I found for that, is pressure wash clean and pour epoxy puddles inside where needed .
Got another year or three before new tank bottom weld in became necessary
Reactions: Jimmy L
jack zerkie
I have the three roto mold tanks 9 yrs and still like new rinse every day no smell. Great vacuum hooked direct to tank. Stainless in front tank and I use a extra filter before the tank. Any questions just ask happy to answer them. jz
Reactions: Dolly Llama
Makers should do more to address corrosion in waste tanks. Line them with poly or something. But NO ! They are more concerned about adding too many electronic gizmos.
Zee show a pic of those tanks. Are they the roundish ones?
Tell me about it. I hate these fancy harwil float switches. I’m making my own today.
jack zerkie
Yes 3 little round tanks about 80 -90 gals capacity.
sassyotto
Paul
just coat the bottom of the tank with Flex Seal either when new or completely dry (with heat lamps), scrape and coat if used. Easypeezy
But will the plastic tanks hold up to a bigger blower like a 47 or 56?
And will the plastic degrade over time and get brittle from age and chem use?
Made for low lift, low flow electroSUX mounts.
And made by mytee gives me caution
I was curious because my buddy bought a bunch of molded chem shelves. They all are sagging now :(
jack zerkie
Not sure how much suck for your buck you can get but I know you can use a hammer on them and they hold up fine. Their very strong and made well. You can check with Mytee and might have the info. Mine are 9yrs and next to the engine heat and no problem as of now. If you look on Cobbys site they also have them.
