icleancarpetz
- Mar 7, 2015
- 1,706
- Name
- Rafael Samson
Looking to replace the steel waste tank for a lighter tank. Who makes poly waste tanks or similar for truck mounts
Tell me about it. I hate these fancy harwil float switches. I’m making my own today.Makers should do more to address corrosion in waste tanks. Line them with poly or something. But NO ! They are more concerned about adding too many electronic gizmos.
Zee show a pic of those tanks. Are they the roundish ones?
Yes 3 little round tanks about 80 -90 gals capacity.I have the three roto mold tanks 9 yrs and still like new rinse every day no smell. Great vacuum hooked direct to tank. Stainless in front tank and I use a extra filter before the tank. Any questions just ask happy to answer them. jz
Do they work well?Yes 3 little round tanks about 80 -90 gals capacity.
Do they work well?
Yes nothing to rust all just the plastic tubs. Each tub has a roto top and always flush the center tub to clean. jz.Do they work well?
I was curious because my buddy bought a bunch of molded chem shelves. They all are sagging nowBut will the plastic tanks hold up to a bigger blower like a 47 or 56?
And will the plastic degrade over time and get brittle from age and chem use?
Not sure how much suck for your buck you can get but I know you can use a hammer on them and they hold up fine. Their very strong and made well. You can check with Mytee and might have the info. Mine are 9yrs and next to the engine heat and no problem as of now. If you look on Cobbys site they also have them.But will the plastic tanks hold up to a bigger blower like a 47 or 56?
Made for low lift, low flow electroSUX mounts.
And made by mytee gives me caution
Always on the finger with the missing nail... Jeez.
