- Oct 6, 2006
- 117,123
Just the wanding portion...not vacuuming, pre spray or scrubbing..
I never wand a staircase. I use the appropriate stair tool. About a minute per stair, give or take a little.Just the wanding portion...not vacuuming, pre spray or scrubbing..
Feels like a lot linger than it is..
Video forthcoming..
Exciting isn't it Jimmy? I forgot, you don't have stairs in Nebraska.I CAN'T WAIT!
About 75-90$ worth...Just the wanding portion...not vacuuming, pre spray or scrubbing..
Video forthcoming..
I'm holding sumptin!I’m holding my bladder in anticipation.
20 minutes incl scrub extract and buff
Buff....come on...how often does that really need to happen?
Did you cuff the bullnose?
Wouldn't work here. You'd end up with brown noses.I run the glide along it side to side on my way down the first time.
This staircase is at my Marine base where I do the upstairs carpet first then all the vinyl downstairs. I get to feel the carpet as they dry over the next hour, which is really f'n fast, bullnose included. Never had a redo there in 90 plus visits.
Been doing it this way for longer then I can recall, as do my 4 techs.
Maybe you need a Girl Guide to help you.Wouldn't work here. You'd end up with brown noses.
I'll scout around for oneMaybe you need a Girl Guide to help you.
I don't see how the glide is going to get the whole bull nose, especially the lower part. Seems like it would be a bit of a struggle. When I am cuffing the bullnose, I can really feel a lot of moisture on the lower part. I would have to reverse the wand to get at it. Just seems easier to cuff it.
I do tend to get them quite wet if they are heavily soiled. Some times I even scrub with a brush.The key is to not to over wet ot in the first place.
ESPECIALLY noses that are severely hard packed with dried mud.
You aint getting it all out sork out disengaging the carpet and pit washing, so just clean ...." enough"....
Mike might have a used one in the outhouse.I'll scout around for one
Really?Mike might have a used one in the outhouse.
