The CRB/Tom Wand fad is wrong.
FB7777
how does a pulse dampener effect PSI?
he could remove the dampener and screw a plug in the hole temporarily to find out if that's it, no??
I'd do that before I let Butler hose me on their price for a dampener
I’m picking up a new unit in 12 days and they only warranty the chem system for 90 days Probably why Hagopian uses a different one on their fleet
FB7777
They seem to be pretty resistant to change. Couldn't they just drive the system off a pump cylinder like PC does?
I wonder if it's reliability has something to do with gravity fed fresh water tank? Does any other system not have a demand pump?
Grand Rapids, MN
Butler Chem systems just like PC actually
Stainless steel block.
Set of Plunger and plastic disc and some check valves and o rings.
Simple to work on actually
I can swap out a rubber diaphram on site easy peasy.... And shoot a video 😁
Reactions: Matt B
KevinD
Binghamton,New York
Kevin Dumas
There's no comparison. My Butler is limping right now with a pulse in the line and I can't draw rinse at all. I have a pulsation dampener that will be delivered tomorrow that will hopefully clear it up.
I had a problem just like that and it was a tiny sliver of brass from a threaded connector got logged in one of the cat pump check valves and would not close.
San Francisco, CA.
Them flood jets were a bitch to unplug
Until I got smart and cranked it up to 1500 psi
After removing the jets, I use a beading needle to unclog the jets from the inside when high PSI wont work. beading needle are smaller then sewing needles.
cape coral fl.
jack zerkie
Most systems require water in all hoses. When your solution tank is empty your system will spike and slow the water flow. Once the tank is full and bled no problem with pressure and flow. Very simple system but very important to flow properly. jz.
Donwand
east coast
Brian
Good luck Russ... I've spent thousands over the years trying to get the Chem meter system operating correctly on our Butlers....
Only to have them crap out again within a few months
I shut the ball valves and take it out of the equation... clear water rinse only
I had the exact same problem with both of my Butler units. I do clear water rinse and it solved the problem.
Acp
Seattle
Bjorn Marshall
welding tip cleaner tool works well too
Russ T.
Slater, IA
Russ Terhaar
been saying since then too
the guys that advocate fresh water rinse..DON'T have a reliable working chem pump
Agreed Larry. I want to leverage EVERY advantage while in a custys home. Other than faulty chem systems I can’t think of any reason not to be running a rinse.
This thing is frustrating. I wear all the hats in my biz and when it’s time for me to put my mechanic hat on, I get a bit salty.
I haven’t even called Butler in a couple days because I need a break and it’s been too cold in IA to be messing around!
