- Oct 7, 2006
- 49,953
Had to have my radiator replacedWhat kind of maintenance are you doing?
YesIs the truck running? Or are you hoping for divine intervention.
Don't chew gum and bleed at the same time.I just saw another bubble
Usually not but you can have them installed. Be glad you have bleed valves on your heat exchangers. I am having problems with my hydramaster cds exchangers but don't have any bleed valves. I back flushed them and got a lot of debris out but I think when I put it together again, I may be getting an airlock. First heat exchanger gets hot, second one, not so much.I’ve never had a direct drive but are there shut offs between the radiator and the HXs
Better heat exchangers for sure.I seriously think Butler and Cleanco are the only two worth buying
Bastards!!Mosquitoes are out in January!
Don't confuse him, any more.Those bleeders screw in to open right ?
