Acp
- May 15, 2017
- 1,093
- Name
- Bjorn Marshall
does anyone run 3/8 solution line?
too heavy and no reason for it. Steamway units used to come with it.does anyone run 3/8 solution line?
1/4 ones from home depot are the best ive found
I noticed some aero techs with 1/4in but isnt max flow with 1/4 only about 7.5 or so? how can u get the big flow with 1/4don't know why we bother
you can lead a horse to water
but they're still pack following dumb animals
for about 30 seconds....
Powermatics came with 3/8 steel braid Ineptune
It weighs a ton and is way overkill for CC'ing needs
I changed fittings and use it for hi GPM pressure washers
Sorry but another hose question. Are there any American hose shutoff connections for the end of the water supply hose 3/4 connection. Not the junk at Lowes & Home depot? jz
What is "big flow"?I noticed some aero techs with 1/4in but isnt max flow with 1/4 only about 7.5 or so? how can u get the big flow with 1/4
I heard some run like 16-18 flow with vortex/aerotechWhat is "big flow"?
Boring Flow Techie Stuff
I posted this on another board, mainly to help the less experienced folks out there. Not sure if any of you seasoned vets can use it, but just in case, I'll post it here too. First up is a standard nozzle flow chart. It seems every time I need a value, the charts out there don't list it. Maybe...mikeysboard.com
100' of 1/4" is good for 3.5+gpm ..... that is a lot of water
the only problem I have with the brass ones from hd is that the lever falls off.
