Quality ball valves?
1/4 ones from home depot are the best ive found
don't know why we bother
you can lead a horse to water
but they're still pack following dumb animals
does anyone run 3/8 solution line?
for about 30 seconds....
Powermatics came with 3/8 steel braid Ineptune
It weighs a ton and is way overkill for CC'ing needs
I changed fittings and use it for hi GPM pressure washers
Acp
Seattle
Bjorn Marshall
I noticed some aero techs with 1/4in but isnt max flow with 1/4 only about 7.5 or so? how can u get the big flow with 1/4
7.5 what, Bjorn?
don't know how much water can fizziclly go thru 100ft of 1/4" @500 psi
the question more important is, how much can go thru the wand or tool plumbing and does 1/4" provide "at least" enough GPM volume for any one tool
would seem the bottleneck to GPM possible would be at valve, QDs and jets
and/or those gawdawful burn blister making 1/8" steel brake line supply line ...on some tools
but honestly, I don't know that
and far too dUmb to know how to calculate such.....
cape coral fl.
jack zerkie
Sorry but another hose question. Are there any American hose shutoff connections for the end of the water supply hose 3/4 connection. Not the junk at Lowes & Home depot? jz
unless you're going to put a heavy duty $20 dollar house plumbing main shutoff ball valve on the end of a hose ..
just buy a dozen of these
89743
89744
they last as long as the brass body ones of similar cheap design .
at a 1/3 of the price
often found at Big Lots for 99 cents
and they take a whole 10 seconds to change when one crAps out
which will be a couple/three a year or every 600-700 machine hours
.L.T.A.
the only problem I have with the brass ones from hd is that the lever falls off. I solved the problem by backing the screw out, putting in some silicone and retightening it. They will work forever.
Reactions: Greg Miller
What is "big flow"?
100' of 1/4" is good for 3.5+gpm ..... that is a lot of water
Acp
Seattle
Bjorn Marshall
What is "big flow"?
I heard some run like 16-18 flow with vortex/aerotech
edit: I can't write this post where it makes sense
Reactions: FB7777
