- Feb 4, 2016
- 14,521
- Name
- Matt w.
I do. I’ve been using the 175 crb mop method and I’m looking for a more efficient method, so I’m doing some research on combining two of those three steps. I’ll probably use the 175red pad to strip acrylic in combination with one of those machines.It couldn't possibly be any worse...
Jhc Matt, do you not absorb anything you read here?
I read your comments about how it doesn’t go deep enough to get all the dirt out. That’s why I’m thinking about paring it up with my buffer. This machine has to perform way better than just a mop. And look like it’s worth $1/sq ft also. It’s hard to prove to the customer that your mop bucket is worth $1/sq ftIt couldn't possibly be any worse...
I did that method also. Caused the hardwood to curl up. Very low psi. Only one pull back wet pass. Nope. The tm stays on tile and carpet.I'll sell you my pmf hard surface wand for $200 plus shipping
The Dirt Dragon is all looks and not even built that well. Lots of parts that will break if banged around in the van.
It does make a nice marketing photo but not really worth what they go for.
I dont do a lot, flat mop on a neutral, red pad scrub, wand rinse, flat mop dryDon't over wet wood. I just wand most wood floors. No prescrubbing. Wand and flat mop dry.
I hate these stupid little chemical tanks on those machines. I'm targeting big hardwood floors, not little house rooms (12X14'). I just put a bid on a 35X75 roomits too big for residential its for malls supermarkets etc... you'll have tourettes before you get it inside
demo a karcher if you like grey
or a windsor if like blue..
..or use your TM after a 175 or crb scrub
12 US gallons is around 45 litresI hate these stupid little chemical tanks on those machines. I'm targeting big hardwood floors, not little house rooms (12X14'). I just put a bid on a 35X75 room
This was the method I used on that day it curled up. It was a race to keep it damp so I could rinse it. There’s too much time involved to let the water get too deep before you extract it
That’s starting to make some sense.Dultmeiers makes some "Misting" jets for car washes.
Would putting them on a hard surface wand work instead of regular T-jet or V-jet spray tips?
I did very light, very low psi that day and had a snail van behind me. Did you see how light I misted the solution on the floor? Mikey’s suggestion using a tm is wrong.over three minutes of running a rotary over 40sf....
a 5 minute vid that could of been condensed to 43 seconds
any wood without a finish (like worn off) can get raised grain with any amount of water.
curled ends or buckling means it was flooded and stayed wet for some time
or...it's cheap crap laminate garbage
That’s a good idea, but the moisture still sits too long on the floor after putting the 175 down, unless you have a 2nd person wanding right behind you.Dultmeiers makes some "Misting" jets for car washes.
I just got the job that I put a bid of .75-$1.00/sq ft that I’m reserving the whole day for. My average day is $600-$800, about 1/3 of this one job. So it’s worth making an effortThe problem with marketing wood floor CLEANING is that for almost the same price there are Craftsmen in your hood that will pad and recoat for just a bit more than you'll need to charge to make carpet cleaner money.
And for about twice your price a full sand and recoat can be found
90% of your estimates will be people looking for a cheap fix to a problem that those pos machines will only make worse.
It might've been curled before. I didn't check. But it was real hardwood, not fake crap. Either way...I hated that process I did.i did
if the edges curled, you simply didn't notice they were curled before you started
even 79 cent sf crap laminate won't curl that quick with that minimal mist.
a mop throws down more water than you misted
can actually make a difference
