Have you tried the 4 port?I disagree that the standard head doesn’t have utility.
LolHe meant the flier
I haven't tried anything yet. Just got the machine and am leaving to Tennessee for a wedding on Thursday. Will play when I get back.Have you tried the 4 port?
I went on the cheap and purchased 2 home depot air movers, the best Shark vacuum Costco carries, and 3 wall corner guards. Trying to look legit and do a good job. I can afford one more tool, then it's time to make money and work my way up.Most of us started with portables and eventually moved on to truck mounts. You can do good work with a portable system but it will take you longer and your drying times may be longer as well. Think about investing in some small drying fans such as the Dri-Pod. With the system you have, foam is always a problem. Watch your chemical dilutions carefully and carry lots of defoamer. It's not always about what you are using but what the customer or last cleaner has done to the carpet before you.
Don't put it in your prespray. There should be instructions with your cfx where and how much to use. Beware with the cfx unit used alone that if it foams over, it will shoot dirty, foamy water out of the exhaust. Sometimes, crystal defoamer can be sprinkled on the carpet after prespraying. Not the best way to do it but it will help. Just take your time and watch the clear tube on your 360 when you're extracting. Do dry passes until you see very little water coming out. Do a room and out a fan on it. Another room, another fan or move the first one. You will get good drying times and your customers will appreciate it.I went on the cheap and purchased 2 home depot air movers, the best Shark vacuum Costco carries, and 3 wall corner guards. Trying to look legit and do a good job. I can afford one more tool, then it's time to make money and work my way up.
The salesman (anonymous) recommended defoamer either in the CFX or sprinkle on the carpet. Which would you do or should I put it in the pre-spray instead?
Thank you, and everyone else.Don't put it in your prespray. There should be instructions with your cfx where and how much to use. Beware with the cfx unit used alone that if it foams over, it will shoot dirty, foamy water out of the exhaust. Sometimes, crystal defoamer can be sprinkled on the carpet after prespraying. Not the best way to do it but it will help. Just take your time and watch the clear tube on your 360 when you're extracting. Do dry passes until you see very little water coming out. Do a room and out a fan on it. Another room, another fan or move the first one. You will get good drying times and your customers will appreciate it.
When watching the clear tube will I be able to tell if there is a foam problem? If so, what will it look like?Don't put it in your prespray. There should be instructions with your cfx where and how much to use. Beware with the cfx unit used alone that if it foams over, it will shoot dirty, foamy water out of the exhaust. Sometimes, crystal defoamer can be sprinkled on the carpet after prespraying. Not the best way to do it but it will help. Just take your time and watch the clear tube on your 360 when you're extracting. Do dry passes until you see very little water coming out. Do a room and out a fan on it. Another room, another fan or move the first one. You will get good drying times and your customers will appreciate it.
If the CFX is in another room.When watching the clear tube will I be able to tell if there is a foam problem? If so, what will it look like?
I ask because I'm not sure how I will know if the CFX
If the CFX is in another room, how will I know if there is a foam problem. Other than an irate customer?When using a portable, I usually spray defoamer into my vacuum hose when needed.
You will have zero vacuum and the machine will sound very differentIf the CFX is in another room, how will I know if there is a foam problem. Other than an irate customer?
Ha
Defoamer is so 1990's
Yes. It happens. I was referring to chems we use in our trucks now. Not what the old guys are using that foam. The preaprays out now really don’t foam. The only issue i have now is the spotters foaming up in the hose. But nothing a little burping doesn’t fix.![]()
Reduced my 870 to a porty.
Yesterday I got a call from a customer that someone had poisoned her dog and he (the dog) defecated all over the carpet. I get there and my eyes immediately start burning when I walk in. I could barely inhale due to the strong odor. The smell was of extremely strong cat box and urine. The...mikeysboard.com
Yes. It happens. I was referring to chems we use o. Our trucks now. Not what the old guys are ising that foam. The preaprays out now realy don’t foam. The only issue i have now is the spotters foaming up in the hose. But bothing a little burping doesn’t .
Fixed my typos. Its hard to drive, eat donuts, and text.Good times. I’ve had customers use Purple Power, Dawn and Windex in their DIY efforts. Those cause some serious foam as well.
Also. Burping a portable is fruitless.
Ummm.Fixed my typos. Its hard to drive, eat donuts, and text.
Liquid presprays followed by either liquid alkaline or acid extraction detergents will foam more than powder equivalents. Powders need to be dissolved completely before use otherwise they will eventually clog your systems.Yes. It happens. I was referring to chems we use in our trucks now. Not what the old guys are using that foam. The preaprays out now really don’t foam. The only issue i have now is the spotters foaming up in the hose. But nothing a little burping doesn’t fix.
I take it your telling me to use my noodle and make sure to use separate circuits?Run the 360, the Ranger with heater and your fans, and see if your fuse box services
Good post, I learned a lot from it.![]()
It's like in the post, it's what the guy before put down. Not what we put down. That's what you're educating me on, right?Yes. It happens. I was referring to chems we use in our trucks now. Not what the old guys are using that foam. The preaprays out now really don’t foam. The only issue i have now is the spotters foaming up in the hose. But nothing a little burping doesn’t fix.
I've never heard of them. It still goes back to the same plug/circuit. Kind of like at the office desk where I have 5 or 6 things plugged in. How do they work to stop the overload of a circuit?Do you have a 220V splitter box? This helped me greatly when I was a proty hack.
It allows the use of the 220 v circuit for 110 v devices? More amps available. Great tip.I've never heard of them. It still goes back to the same plug/circuit. Kind of like at the office desk where I have 5 or 6 things plugged in. How do they work to stop the overload of a circuit?
Where are they sold? I looked on Home Depot's website, under 220v splitter box and got pictures of outlet boxes.Do you have a 220V splitter box? This helped me greatly when I was a proty hack.
