Daily reports...
Bc
Tomorrow, apt windows and carpet (all exterior, all common spaces), Friday, 5500 sqft PORTY job.... guess we will see what the monsoon can do...
Reactions: Hack Attack
Grand Rapids, MN
I cannot even list all of the jobs that have come in. We went from enough to keep me really busy to totally insane!
Governor still waffling opening up the State.
Most people have had enough. They have been inside with cabin fever too long with typical winters and now ready to get on with life and not die in their living rooms in their underwear (client quote)
Son in law a trooper and sees big picture. He is giving up extra government money. Time to work for our keep.
Young guy OK so far with coming back to work. If not, we have some others looking for work vs a free meal ticket!
I'm ready!
I went for a ride.
Jim Williams
Bynum N.C.
Jim Williams
5 jobs this week and already 5 for next week. I think a lot of folks don't realize I can work legally so if Gov. Pinhead opens the state up May 8th hopefully I'll be running at full capacity. We are one of the lower impact states but some governors want to see how long they can drag out the misery.
The reason for the shutdown was to keep hospitals from being overwhelmed. I had to take my wife to the emergency room last week for an allergic reaction and the place was deserted. Time to reopen!
Willy P
Vancouver
Willy P
Team work. With a 2 man crew you should mow that down in 6 ro 8 hours. Switch off on wanding and waterboying. The pump on your machine needs to be retrofitted. I saw one today that my repair guy had. Diaphragm pumps have their place and it's only a 1.6 amp draw but you might be able to put in a higher pressure pump. I've switched to Cat 1xp instead of pumptec because they're easier to get and service up here. Also, downsize your jets if you want to keep up the pressure. With a 3 flow you're likely to get 150 psi when keyed.
Bc
Great advice Willy, thank you.
seattle
Spent the day at the Marina painting the wood on my Dad's Sailboat. Been cleaning and fixing things for 2 weeks now. We've never given the boat this much "Love" in 30 years.
Takes a special person to keep a boat that long.
My dad had a vintage Chris Craft that wasn't moored under cover, and all I remember of summers as a kid is working on that boat. The smell of varnish and the marina shore at low tide still reminds me - no wood boats!
seattle
Wife works in a hospital that vacated a floor for isolating COVID patients. Never filled it and their now cutting back to a few quarantine rooms. We're opening back up on Monday even though our Guv has extended the stay home order. So far customers are overjoyed, so looking for a busy
Reactions: Jim Williams
scotty747
At least you got your monsoon. I'm still waiting. Why not run a hose from the janitor closet if its only 200 ft. to fill? 4 50 footers of hose will fill faster than you can work. Then the bucket brigade is just for dumping.
Make sure your hose is rated for hot water. Ask me how I know.
Willy P
Vancouver
Willy P
Cleaning with Luke warm water is a pain. By the time you get through 200 feet of hose you'd be lucky to have 70 degrees. Maybe run the waste pump out that way but not to fill your fresh tank.
Benton KY USA
Good 3/8" air-hose tolerates hot tap water well and will flow plenty. The smaller diameter means less water is "standing in the pipeline" and the cooling effect is minimized.
Easier to wrap up and transport as well. Several times on huge projects we skipped the autofill and machine pump entirely, thus going tap to tool directly.
scotty747
I was thinking just use your usual solution hose. Faucet hose adapter straight to the 1/4 inch with no quick connect to restrict flow from water supply. I forgot theres no heater in the monsoon.
Reactions: Papa John
