Be honest, what percentage of stairwells really need the riser cleaned?
I started to like the above comment but I talked myself out of it by suspecting he doesn’t edge vacuum,
Marty. You should have seen the job i had today. A vacant office building with 3k sqft of CGD. The place was a total mess. Broken glass and paper clips everywhere. It took me an hour just to vacuum and edge the place.
what percentage of stairwells really need the riser cleaned?​
100 percent. Why?
1. Ive seen posts where they say "they dont look dirty". Well Ive cleaned plenty of carpet that at first didnt "look dirty" where in fact after cleaning made a big difference.
2. If you skip this step, it leads to skipping other steps too. After awhile your just like everyone else, so how do you differentiate from everyone else?
Just today I had a set of steps where the risers were bad. Took an upholstery bonnet to them and they looked like new. Thats the rare case tho.
But if you want to be a 2 percenter you better clean 100 percent and give 100 percent effort, 100 percent of the time.
2%r's use two jet wands... 😵‍💫🤪
I'll sell you a new one with a Glide if you don't bitch about it
Maybe Matt would know if my Extender Benders will work with it, IM guess it they will, so insted of spray down, and soaking the riser, it'll strike right behind my flat face'd Glide.
I would want to install and test before sending it on to you.
Bc
That PMF in a 30” version, with a FF glide, tweaked jets, would be my personal preference for a stair tool.
HOWEVER, the 40” is what I’ve been using for almost 12 years…
your extender benders are probably the best thing you've come out with. I used your flat faced glide for the first time yesterday and was very pleased.
You really need to check yourself and take my feedback seriously. I used more stair wands on my career than you've probably heard of, because a man of my height 6'5" isn't very confortable cleaning stairs with stair tools, so I found the perfect shape to clean stairs with only 1 tool. I've read that people on here have used 2 tools (wast of time) to clean risers and landings. This is a job, not a hobby.
I’ve admitted where I was wrong on my feeedback of tools, (zipper was one example)
over all my rantings of my frustration with these overpriced tools out there, feel free to ask
I'm thinking about getting a little wiener dog long hair puppy. They are too cute to resist.
The curve at the handle doesn’t make cleaning risers “no problem.”
You're right, but it saves your back from being terribly sore at the end of the job.
The straight connection at the head of the wand makes it no problem. The curve at the handle just helps you not want to bend over, like that pmf straight wand pictured above. When it's totally straight, you are needing to adjust your stance to keep a solid connection parallel to the carpet, which causes you to bend over. Put a curve at the handle and your back won't be sore
But if you put a curve at the head, creating the "S" shape, your wand will have to be positioned too far forward while doing the risers, which will cause the vacuum hose to want to pinch, making the risers very awkward because you'll be trying to clean and maintain the hose.
Mike, is that a good enough explanation? I"m not the average rug sucking idiot. I could clean around you guys while you're still setting up.
Both of you are ignorant. Mike, I'm sorry, but your stair tool isn't perfect. I have the pmf "S" shaped one and I rarely use it for that reason.
Marty.......ahhh, I'm tired of explaining you
I rarely rinse and extract the risers any more. Anytime I do try it just over-wets the bullnose and is really doing more of a disservice.
We prevac all areas of the steps (which 90% of people do not) and then pretreat the steps only. Drill brush if necessary. Then rinse and extract. If I do see that a riser has a spot on it, I'll mist it with my wand and then dry stroke it.
I think there's a good number of carpet cleaners out there over-wetting. The sad thing is, is that there's people like Roger Lloyd training people to do it, so they don't know any better.
Release the trigger sooner
