100% VLM ???
Yes, I'm aware. I certainly wouldn't use my porty at 250 or even 75, that would be my TM😀 It would
clean better than an opee. I could sound like Larry🤣
they live
Steve
Nasty day outside
35 degrees Heavy Rain Wind Damp Cold and Miserable
But my Van Doors are closed and customers House Door is closed. No heat getting out or cold getting in
Working in Bad Weather is much easier and better using the VLM Method
And carpet will be dry in 1-2 Hours
One of the girls that works at my Apt Complex is moving into a new home and she asked her favorite carpet cleaner ME, to freshen up the carpet before she moves in
Nice Big House with Nylon carpet
I used Carpet Details at 4 oz and Detonator ( Peroxide ) at 4 oz
WORX Sprayer with 8003 Teejet
Light Blue Microfiber Bonnets and Tankless Vibe with 3 weights on each side
Soft White Brushes on CRB's to scrub and Groom
Life is BETTER using the VLM Method !!!
Did you post vac? So the job isnt done.
Did you pre vac because i dont see one?
they live
Steve
Living The Dream, when you pre-spray at 400 psi do you think that you get the backing of carpet and possibly the pad wet ?
You do realize you are getting the pad wet also right? Gravity and all.
But with hwe you can remove most of your detergent with the soil not just grind it deeper and spread it around.
Carpet manufacturers still overwhelmingly recomend HWE. You can very easily damage fibers with all that scrubbing. You can change the texture. Ive done it with a crb and a buffer even a little with my wand and hot water.
View: https://youtu.be/s6vgeEZEnJk
If you are 55yo+ you are eligible for vlm cleaning, not because it cleans better but because it's easier on the frail aging body..
Now if you can just get Mikey and whoever else to put it in the cleaning standard..
Vonshrader is a good option too.. Do you offer Host as well? Capture perhaps?
Dwain Ray
Watch it there sonny, don't make me pack a pile of depends fly all the way to Hawaii just to beat the crap outa you with my walker! i can still hwe with the best of um😂🤣😅
SteamwayPro
George
Do you post vacuum after HWE
HWE leaves a lot behind. Dirt and powder residue
HWE takes longer to dry so you can't post vacuum but what you should do is ask your customer to vacuum the next day
And customer should vacuum the next day after VLM too
I don't usually post vacuum but I do CRB to groom
LESS water MORE agitation !!!
