E
EDS
So I'm using a 13' ZIPPER a 7 flow but my machine can't keep the heat up to what I am accustom to. Will going down to a 5 flow make a noticeable difference?
Thank you in advance...
No. Tried finding one up here with no luck. And big difference with the trigger. Still learning how to use it.Do you have a lie detector at the wand?
Holy crap you guys are tempemental...I guess that's what happens when you become old and wealthy
I'm kinda tone deaf but I will take that as a diss.
It was a simple question not meant to stir the pot...
My apex is older so it may not perform like the new ones. If remember correctly were you not running a 5 flow with your 370?
Anyhow I have a bath to take in the hot tub and stew on my first world problems...
Cheers,
He moved to mountains where there isn't enough oxygen.I was expecting that Mike at MF
Oh the last time I did that it litterly looked like I did pull them out...$700 repair bill at my local rad shop-Pull your heat exchangers and clean them.
Oh very happy with the way it cleans and more importantly how dry the carpets are after. It may be a ID10T error with my use. Went to Cleanworks shop yesterday and he gave me some tips on use.The problem is not as much your flow rate as it is the length of time you stay triggered.
The question that matters to me is ,are you happy with how it cleans? My 870 will drop to 200ish with 12 flow zipper wide open for a long time. I don't see any difference in results.
A brother! Finally someone with the same mechanical skills as Marty and I.Oh the last time I did that it litterly looked like I did pull them out...$700 repair bill at my local rad shop![]()
I thought it was an attempt at hillbilly.Is ranch Yiddish for wrench?
