Marty...no I do not have some petty grudge with you.You said you tried to be fair...if you have never used a cimex and then give an assessment,your decision is therefore only bogus.Besides we all know that you have a dislike for encapping.
Speaking of intelligence...my 10 year old nephew even knows that in order to give a fair opinion on between 2 "things"--whatever the debate may be about,is that
both have to be equally tested in order to give a fair assessment.
Most cases Marty,I like reading your posts,as well as others.The exception is when you climb up on your soapbox and act as if only your answer/way/opinion is the only one that matters.
"the dude is trying to learn something"
A one sided answer will not help him.
You can provide soil transfer with a cimex if you use some of the synthetic "bonnets",not as much as an OP but definately enough to use it.
OP and Encapping w/ a Cimex are two entirely different beasts,they are not two types of apples.More like apple and oranges.I have used both on the same contract,same service day or seperate.Some areas will require at different times different tools.No matter which tool;OP or cimex,we use Release-it DS and or
Punch.
Everybody has their favorites.I've gone from Release-it to CCS's to Vacaway and back to Release-it.Why?....why change for the sake of change
onlyIf it isn't broke,don't fix it.
I do have to say for the sake of discussion,that my OP use is with a smaller unit rather than some of the newer,larger ones out now.Its not like I can go over to one of the local suppliers and try one out :shock:
Marty there is no disrespect intended.i have got to remind my self that you're an old man who is just set in his ways
Patrick
