- Joined
- Oct 6, 2006
- Messages
- 117,352
that being sED Ken...there really aren't any other Direct drive TM's out there ...worth a damn!Ken Snow said:Bawb- I have sold close to a hundred "used" Butlers and all the one's I know of have no problem getting parts from Butler- though almost none are needed as they almost all able to be bought from other local sources. The only time I have heard (don't even know if that is true) that someone has had a problem is if they used some schlock mechanic to take a butler out of a van and put into another. This is verboden and I have no problem with them sticking to their guns and not supporting that (if they don't).
There are lots of great machines out there, we choose to use Butlers and find them to be a great system for us.
Ken
sorry Ken..i thought yous was up to speed on this thread.....it WAS about propritary parts on a machine that makes it hard or impossible to run.........Ken Snow said:We have no problems with our cat pumps Bob, and to me knowledge not a big issue with the limit switches & solenoids. Periodic replacements yes, but not requiring field mechanics.
What does that being said mean? I refute your comments and you bring something else up, what's with that? We ran steam genie's for years Bob, I personally cut my teeth on a gnie1 for 4 years. I have no reason to put them or any other machine down. Your reason smells of conflict of interest.
fred boyle said:hey spicoli, you know Genies are being manufactured NEW anymore doncha?
JHC....Ken......i was jus busting yor balls a little to see how you roll.......Ken Snow said:I was totally up to speed on this thread, just did't understand your comment back after I replied to you. I assume that it meant that you agree with me and were overstating your position originally, but I wanted to hear that from you not just assume it.
I don't know if Butler would support you or sell you parts for your "out of the van system", but why would you need support when almost everything is avail to you cheaper elsewhere? Have you called and asked for support? Want me to call and ask for you? I could probably have them put any parts you need into on of the new units I'm getting and save you the shipping costs.
Let me know,
Ken
seriously..the roots blower on that Butler was SPECIAL MACHINED for that tensioner systemKen Snow said:I was totally up to speed on this thread, just did't understand your comment back after I replied to you. I assume that it meant that you agree with me and were overstating your position originally, but I wanted to hear that from you not just assume it.
Let me know,
Ken
YA...that too!steve g said:butler refuses to solve the same ole problem they have always had, which precludes me from ever even thinking they are an option, THERE IS NO ROOM IN THE VAN, why in the world can they not have the console mounted on top of the fresh or waste tank, have the tank mount right behind the seats then just put the console on top of it. that would save a ton of room as the space above it is wasted. PTO machines don't need to take up the entire area of the vehicle.
ronbeatty said:Hey Fred, When you have been around as long as some of the "seniors" on the board, we might start to listen. It always easy to be an armchair quarterback. :wink:
Even if all Vortex support was pulled from me today, it wouldn't have any effect on me. Aerotec is still there and Ted is still available for parts and advice
Doug Cox said:Man - Can I sympathize with V owners on this topic.
GeneMiller said:i never buy anything i can't fix myself. i don't like to depend on anybody but myself. the problem with the vortex i looked at was the complicated heating system and all the switches and gizmos to make it run. it really could be a simple machine box truck, with a pto, drive shaft, big ass blower , cat pump, diesel burner. you don't need fancy switches to engage a pto, just a cable and look at the trucks rpm gauge. a couple of gauges for pressure, heat, and lift.
gene
