fresh water tank, how often do you use it?
LOL you do need to flush the carpets out, but also need the vac. to get the water out I guarantee even though Ron might use that much water he'll get better dry times then your techs...Lol
I use about 30 gallons on 4 room rentals, and the tenant can move in 4 hours later !gotcha!
Cleaning Professional
by the time you prespray a trashed berber, and then rinse it at 600psi, you go through a lot of water.
K
Ken Snow
Re: Re: fresh water tank, how often do you use it?
Berber lol- double OY Vet!!
Sent from my DROIDX using Tapatalk
greenhorn wand and nice slow dry passes
of course its been well vacuumed first !gotcha!
that soil left behind in berber is what will bring you back every time!
Hoody
Cleaning Professional Gold Member
Steven Hoodlebrink
Bowling Green, Ohio
Years of Experience
21
Website
Visit Website
Understanding that many berbers are olefin, which has a lot of oil in the fiber that the soil become trapped into, and learning how to keep it dormant will, and removing more with post padding and an encap will keep you from going back.
I'd bet ya a benjamin, I could come in after you with a 175, an encap, and cotton pad and go around the room and end up with a good year tire looking pad.
well, one day someone is going to actually test that theory.
And of the guys that just go in there with a pad, I'd go in there and fill a canister of soil
FOJL
My tank holds 160 gallons, but I usually don't fill it completely.
However, 600psi atm, 100' 1/4" line, 75% trigger cycle, and at a 6 flow you will actually be using less than a gallon per minute of actual cleaning time.
FOJL
Able 1 said:
6 flow?? Really?
I use six as a benchmark, as it is most common. I typically use an eight or so.
Still would take considerable time to drop sixty gallons on two rooms.
but at 15 flow, you'd go through water at a wee bit faster rate
