fresh water tank, how often do you use it?
Wi
Keith
LOL you do need to flush the carpets out, but also need the vac. to get the water out I guarantee even though Ron might use that much water he'll get better dry times then your techs...Lol
I use about 30 gallons on 4 room rentals, and the tenant can move in 4 hours later !gotcha!
Ken Snow
Bingham Farms MI
Ken Snow
Re: Re: fresh water tank, how often do you use it?
Ron Werner said:
by the time you prespray a trashed berber, and then rinse it at 600psi, you go through a lot of water.
Berber lol- double OY Vet!!
Sent from my DROIDX using Tapatalk
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Understanding that many berbers are olefin, which has a lot of oil in the fiber that the soil become trapped into, and learning how to keep it dormant will, and removing more with post padding and an encap will keep you from going back.
I'd bet ya a benjamin, I could come in after you with a 175, an encap, and cotton pad and go around the room and end up with a good year tire looking pad.
Benton KY USA
My tank holds 160 gallons, but I usually don't fill it completely.
However, 600psi atm, 100' 1/4" line, 75% trigger cycle, and at a 6 flow you will actually be using less than a gallon per minute of actual cleaning time.
