HydraMaster DriMaster 2 Upholstery Tool
http://www.hydramaster.com/Products/Acc ... yTool.aspx
g
Eliminate overwetting concerns and clean upholstery faster with the DriMaster 2 Upholstery Tool. Utilize the power of your truckmount rather than by-passing it. HydraMaster's patented DriMaster™ Upholstery Tool is unlike any tool you have ever used. Using new Jetless Cleaning Technology, it has no trigger valve, no spray jet, and never needs a second drying-pass. The solution is under constant flow, trained by the patented injector bar and slotted vacuum port system. The result is a highly effective cleaning tool that works without overwetting or heat loss. Even narrow areas can be cleaned without any overspray.
Less Operator Fatigue Durable, but lightweight, the DriMaster Upholstery Tool is less than half the weight of other upholstery tools. The new Jetless Cleaning Technology eliminates the need for a trigger valve so multiple holding positions are possible, lowering the potential for hand strain. No second pass, no over-spray, and high-volume water flow all contribute to the efficiency and speed of cleaning. Cleaning with the DriMaster Upholstery Tool is just plain faster. The high flow - low residual moisture effect of this new technology leaves the fabric cleaner and drier while greatly reducing the chances of damage.
Combine the high performance cleaning of the DriMaster Tool and HydraMaster's state-of-the-art cleaning chemistry and you're ready to treat most cleanable fabrics with fantastic results!
Exclusive DriMaster Features
·Patented jetless technology
·Solution is applied in a thin, flat stream for even application
·Cleaning solution is under constant flow, trained by a patented injector bar and slotted vacuum port system
·No trigger valve, no spray jet, and never needs a second dry pass
Contractor Price: $515
Auction starts @ $250 and goes up in $10 increments
Free shipping included!
Ends Wednesday 1/11/12 @ 7PM PST
