jeffexe
- Joined
- Feb 16, 2021
- Messages
- 198
- Name
- jeff
very sharp looking. Might make a nice compliment to my Sharpshooter.
It's not a favorite yet but you never know. Shows that Westpak seems to be listening to feedback from carpet cleaners. Nice improvement over the standard AW29 versions.Another temporary board favorite
I've seen it happen with wear, but I don't think a fan jet should put out more water at the ends. It could be a problem with the overlap of multiple jets, which could be countered by using tapered jets that have a lesser flow at the ends.I didn't see an issue today in fact there's a bit of overlap right there and as you know the spray is always the strongest on the ends with v-jets but if this was a problem they would have addressed it at least 15 years ago when this thing first came out
I have some 04s on order to see what's whatI've seen it happen with wear, but I don't think a fan jet should put out more water at the ends. It could be a problem with the overlap of multiple jets, which could be countered by using tapered jets that have a lesser flow at the ends.
But I'm being pedantic here.
(Thanks Jim.)
Ok, probably doesn't use oxy anyway. Oops.Ive been to his house and met his wife.
You might want to play nice.
Latest loveIve been to his house and met his wife.
Latest? No.Latest love
New love wand too
How long will it last
But, will the difference between wholesale and retail ensure your eternal love?
I did, made me want to go to the alter and get saved againI make way more selling Sapphires
But most cleaners can't afford $1450
Did you watch the soothing finale?
Mike you would love this wand, it's nearly identical to the pro-chem quad jet in every way but you would notice the two Jets and it's additional impact, you could run less water pressure to get the same results, and have better access due to the lower corners for getting underneath certain furniture.PCQJ with the Greenglide on this rug was the ticket. The vacuum was so perfect and a lot of the stroke was just in falling back against the wand. Then the momentum of the forward stroke coming off the hip check. No hinders finishing with a whip on the backstroke or a firm kick of the vac hose was fair play. Went over the whole room a couple times drystroke just for fun.
Still has oversized aviators and wide leg pants from the 80s. They've come back around so he's hip again.Hip IICRC instructor? Sounds like an oxymoron to me.
Probably the same three guys who called to buy one.I'm working in the yard.I get your video sent to me by 3 cleaners.
So from what I saw.
Lower profile and bigger attic area for recovery.
So hopefully they turn into sales.
But around my area.
There is shattered what's left bdcc...the work is there they are just fkn inept. SO...
Wand looks good.
You explained it nicely.
Jets seem to be hitting nice.
So best of luck.
Lettuce no wen da honeymoon ova lidat..
Truth…In fact, If any of you regulars here would like to try one, Ill go $400 delivered to L48
Offer ends next Friday.
NTS, I need to order more Glides
